Need Help with 89 GTA Stereo.
Old May 19, 2012 | 06:56 PM
champam's Avatar
Hi guys, reply here or champam@hotmail.com, if your in Toronto, send me your deets and lets chat..
I have an 89 GTA and the stereo has an intermittent but becoming permanent problem. I have the model with the controls on the steering wheel as well as on the stereo, so when it says "loc" you press mute on the steering wheel and that unlocks it, then the stereo will display the time, and then you have to press the power button on the stereo and it all comes on. The problem is now, when I start the car nothing is on at all, and then totally randomly after some time that whole process will start described above, except when I press power it shuts right back off and nothing will start it. One time out of a hundred the stereo will stay on for like five minutes and then just shut off.. Any suggestions?
Old May 20, 2012 | 12:19 PM
red88tagta's Avatar
Car: Restored 88 GTA
Engine: 5.0
Axle/Gears: Posi
Re: Need Help with 89 GTA Stereo.
The next time it does that. Pull the radio out and look for 12 volts all the time on the orange/black wire and 12 volts on the yellow wire ignition on. The black wire will be the ground. If you have 12 volts as discribed, then you have a problem with the radio.
Contact me through a PM and I will give you my email address. I do repair those radios and have a bench set up to unlock them.
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
