Speaker size question
Old Jun 28, 2012 | 10:52 AM
SRF's Avatar
SRF
Car: 1987 Pontiac Firebird Trans-Am
Engine: 5.7 350 TPI
Will these sony xs-w1620 6 1/2 2way speakers fit in my 87 bird?
Old Jun 30, 2012 | 10:36 PM
mav75's Avatar
Car: '89 Trans Am
Transmission: 700 R4
Re: Speaker size question
Where do you want to put them? The stock speaker sizes are 4"x6" under the dashboard and 6"x9" in the sail panels.
Old Jun 30, 2012 | 11:24 PM
SRF's Avatar
SRF
Engine: 5.7 350 TPI
Where ever I can fit them easiest.
Old Jul 2, 2012 | 09:29 AM
cw3adkins's Avatar
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
You could either run those in kick forms or in the sail panel location (providing you have kick forms or are looking into them). I seriously doubt that you'd get them to fit into the stock front dash location without some serious modification due to the HVAC ducting and ECM mounting location (if F.I.). The easiest mounting scenario would be the rear sail location, if you wanted to use them back there, but it would still require some fabrication with either MDF, aluminum or fiberglass. This all depends on what you want to do and what you feel comfortable with. Since I am not sure of what you are experienced with or what you want to do, I've added some links below for some stuff.
http://www.crutchfield.com/p_044C100...res-Black.html
http://www.crutchfield.com/p_142SA69...-Brackets.html
toronto formula
Nov 10, 2015 06:17 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
