Rethinking my stereo setup in my 87 TA..need input
Old Jun 23, 2012 | 11:48 AM
mrrman's Avatar
I had installed a single din GPS unit with my current setup and now have gone to a DD GPS unit. I currently have 6 speakers installed in the car with dual amps * 2-6x9's, 2- 4x6's and 2- 6" round( in the kick panel). I am thinking now that I should go with just one amp instead of 2. Since I have the car apart now, the change is an easy one. Can someone recommend me 1 amp that will do the job. I am not installling a sub.
http://i559.photobucket.com/albums/s...56-23_0812.jpg
This is what I have now minus the Pioneer brain...just the 2 Pyramid amps
Old Jun 23, 2012 | 07:51 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: Rethinking my stereo setup in my 87 TA..need input
welll whats ur price range?
Old Jun 24, 2012 | 10:18 AM
mrrman's Avatar
$200-$300 approx
Old Jun 24, 2012 | 01:18 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
alpine mrx-f35 is 239 from online car stereo. Use promo code OCSAVINGS. So your total would be 227.05
Old Jun 24, 2012 | 03:03 PM
mrrman's Avatar
How does that amp compare against the Kenwood Kac-9105D? Saw the Kenwood for $134,
Old Jun 24, 2012 | 09:27 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
thats a monoblock amp
Old Jun 25, 2012 | 07:39 AM
mrrman's Avatar
what type of amp should I buy? Since I am only running 6 speakers and no sub, should I get a 4 channel amp?
Old Jun 25, 2012 | 08:36 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
I would get a 4 channel, alpine makes good amps and Kenwood makes decent ones until you hit the excelon line then they're on par with alpines lower end gear. You cab use a 4 channel and run your fronts together but you're only issue is 4x6's generally need to be highpassed, if you run your fronts together on a set of channels then you would highpass your 6.5's as well... Or you cab run your 4x6s separate and then your 6x9's with the 6.5 but then your fading ability is toasted and may be more difficult to tune.
It's a catch 22 here, if you dont care about your 4x6s then just run em how you are but remember that a tiny speaker can only handle a small amount of bass before they distort and sound like crap and eventually blow
Old Jun 25, 2012 | 08:55 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
well you could just get 4 channel, run your 6.5 on the front, 6x9 rear, then 4x6 off the head unit. Thats how I usually do that set up
Old Jun 26, 2012 | 08:13 AM
mrrman's Avatar
Thanks...I think I will go this way...currently looking at a 4 channel Alpine amp on Ebay
Old Jun 26, 2012 | 01:38 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
If you run the 4x6s on deck power they're at a higher risk of distortion. And having 4 other speaker amplified with much higher output by size alone the effects of the 4x6s would be so negligible you may as well not use them. I say your best bet is to run the fronts together and the rears alone and just go easy on the filter so your 6.5s aren't totally bass free and the 4x6's are still safe
Old Jun 26, 2012 | 05:54 PM
mrrman's Avatar
How would I wiire it up then if I bought this amp?
http://www.ebay.com/itm/Alpine-MRX-F...7f960a&vxp=mtr
Old Jul 2, 2012 | 09:43 AM
mrrman's Avatar
closed .... picked up an Alpine
MRV-F450
5/4/3 CHANNEL POWER AMPLIFIER
Hotrodboba400
Dec 10, 2019 07:07 PM
HP52TA
Feb 3, 2018 10:51 PM
customblackbird
Oct 1, 2015 04:30 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
