Installed kenwood CD player dash lights went out
Old Oct 7, 2012 | 09:15 AM
Lo3 maniac's Avatar
Car: 1990 camaro rs
Engine: 5.0 305
Axle/Gears: Limited slip 2.77 gears
Like the title says I put in a kenwood CD player and after the install my dash light, the heater controls, and the lights that indicate what gear I'm in also went out any help on this?
Old Oct 7, 2012 | 09:29 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Installed kenwood CD player dash lights went out
Well, check the fuses for INST LPS and TAIL. Did you hook up dimmer or headlight signal wiring to the radio, if so disconnect it for now. It would be a gray wire that has the dimmer voltage on it.
Old Oct 8, 2012 | 11:59 AM
oif0709's Avatar
From: http://www.facebook.com/ThirdGenCamaroFirebird
Car: 1987 Camaro Z28
Like afremont said, you blew a fuse. Check your grounds and make sure the power and constant wires arent exposed.
Old Oct 8, 2012 | 12:29 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Yeah be careful with those. They're the RADIO and ARC fuses. You can do some damage with that ARC wire being hot all the time and able to cough up 20 Amps worth of fireworks which you likely wouldn't enjoy.
<PREACH> Man I don't want to be a mother hen, but you can't use too many fuses when you add your own wiring. Always fuse it as close to the source of power as you can in case of a short. Many many moons ago I had an 8-track in my car wired to an unfused area of the fuse box. I had a short to ground on the 8-track player end of the wire and well you know what a toaster element looks like I suppose. :0 Trust me, you don't want to see three feet of wire light up like that inside your car. All the insulation just dropped off the red hot wire. I was fortunate that the harness side of things didn't do the same thing, though it would likely have popped a fusable link somewhere since the factory has more sense than me when it comes to safety. I was lucky in that my wire was small enough that I didn't have that happen. I was also lucky in that the wire draped across my leg didn't slice into me like a foam cutter. <PREACH OFF>
Old Oct 18, 2012 | 09:37 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Check which wire you connected the radio ground to. It should be connected to the BLACK wire in your dash, not the brown one.
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
