shallow headunit?
Old Oct 27, 2012 | 02:27 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
shallow headunit?
ladies and gents,
I have a universal headunit install kit, and i hate the way it sticks out past the dash in my car. does anyone know of any headunits that are shallow enough to sit the faceplate flush against the dash?
The colors need to be adjustable so that I can match it to my interior lighting. The headunit needs to have a front input for a USB thumbdrive and it needs to be able to play MP3s. I wouldn't mind bluetooth compatibility either.
Thanks!
Bill
Old Nov 25, 2012 | 08:52 AM
theBIRD2445's Avatar
Car: 1991 Firebird Formula
Axle/Gears: 2:73
Re: shallow headunit?
if youre taking about the headunit itself that is sticking out, there is a plastic braket in the back of where the radio goes that helps support your original radio.(its where the peg on the back went) cut that bracket out with a dremel, or other tool, and youll slide all the way in. hope this helps
Old Dec 7, 2012 | 07:41 PM
Warlocksirix's Avatar
Car: 1991 Firebird Trans Am
Engine: 5.0L 305 TPI
Transmission: 4S Auto
I just did this to mine I didn't have to cut all I did was remove it by taking out all the screws pulling out the whole radio holding cell and unscrewing the brace bar going across the back.
FYI there is a small bolt/nut in the center near the area where the oem radio holding hole is that mounts the whole cell to the car body. Make sure to take that nut off (it's on the floor next to the area mentioned) and it'll slide right out once you take out the other 2 screws and unscrew the climate controls.
Old Dec 7, 2012 | 07:52 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
i flipped the bracket over i also had to notch the heating duct since my radio hit it
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
ChevyLuva3
Car Audio
27
Mar 7, 2002 09:23 PM
jobryan26
Car Audio
32
Jan 5, 2002 11:34 AM
PhantomTPI
Car Audio
Apr 23, 2001 09:19 AM
