Dash & Rear only... No kick / door speakers..
Old Dec 12, 2012 | 07:30 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I have a 2 way 6.5" for rear... a 2 way 4" for dash and a 6.5" mid range I was wanting to place in the door / kick panel....
My thoughts are, should I even bother with the 6.5 mid range?
(I will also have a few 8 inch subs in the trunk)....
The rear speakers are going to be so close to my ears anyway...
Any thoughts from those that already have a similar system?
Thanks,
Rafael
Old Dec 17, 2012 | 09:16 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: Dash & Rear only... No kick / door speakers..
The problem with the dash speakers is that they are just so small that all they will produce is highs. Plus it will sound like all the sound is coming from the rears. If you can find some kick panels you like, I'd run the mid and put a tweeter close to it.
Old Dec 17, 2012 | 09:26 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Q-Forms: http://www.qlogicdirect.com/index.ph...1765564fbdee39
Old Dec 17, 2012 | 09:32 PM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
I have the pioneer 4"x6" front speakers in the dash with a separate 35 watts per channel RMS amp, alpine 6"x9" speakers in the b pillar with a 150 watts per channel amp and an infinity self powered subwoofer with 10 inch speaker and I think 300 watt internal amp.
The sound is amazing and I don't think adding any midrange to the kick panel would do much to improve the sound.
I do suffer as mentioned before that the driver side b pillar speaker dominates the sound except for the sub. The front speakers just can't handle enough power to catch up with the b pillar speakers without frying them.
Such as life in the third gen. My system is still by far one of the best sounding systems I have ever had and one of the best sounding systems under $1,000 without out multiple large subs and crossovers, etc. I have heard.
I'm sure there are better, but mine is nice and I think you will be satisfied without adding the extra hassle of the kickpanel mounted mid range.
Old Dec 18, 2012 | 08:28 AM
luvofjah's Avatar
Thanks for all the replies....
I'm not a fan of the tweeter mounted in the kick panel, which actually puts it further away from my ears than if it were on the dash... I'll have to see what the mounting depth is of my 6.5 mid... maybe put it in the door... (I know there's not much room...
Rafael
Old Dec 19, 2012 | 09:50 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
well, in my years of audio installation i have found that the kick panel is about the best place to put your front sound. the reason is, it is the place where the speakers are the closest to the same distance from your ears, yes you will need a little more power to them, but it wont be a lot ... i have been building custom boxes for almost 20 years (until my buddy didnt tell me he was losing the shop, and all my tools with it) and you can build a nice kick panel box set at home for around $50, no need to buy a $200 set
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
stalkier
Aug 13, 2015 12:59 PM
