Mounting an amp in the rear hatch area
Old Jan 17, 2013 | 10:35 PM
Oddie65's Avatar
Car: 1986 G92 Z-28
Engine: '89 L98 (5.7 TPI)
Somebody PLEASE help me, I need to know if I can mount an amp (with screws) to the higher floor area in the rear hatch right behind the back seats.
Old Jan 18, 2013 | 12:01 AM
basshead208's Avatar
Car: 86 IROC Z28
Axle/Gears: posi 4 disc 2.73
Re: Mounting an amp in the rear hatch area
Yes. Tho the best way i found was to either use just enough screw to dig into the metal or lift the carpet, trim the pad and put a piece of thin wood panel under it where the removed pad was. First measure your amps feet then drill and tap the wood with small fine thread bolts facing up then put it under the carpet and push them through the carpet then secure the amp down with nuts. can also use some glue under the wood to solve potential vibration of wood to metal. Be aware, theres .75 to 1" of space between the tank and floor. Hope this helps.
Old Jan 18, 2013 | 01:17 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Yes, not hard at all. Just don't punch through the metal and you'll be fine.
Old Jan 18, 2013 | 05:02 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
I put an amp in my 84, used industrial Velcro (the rough side) then placed it on top of the hump. Worked like a champ, amp never moved, and it didnt mess up the carpet.
Old Jan 20, 2013 | 07:50 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
OMG!!!!!!!Thanks soo much for this comment ive been trying o figure out the same thing for quite some time now......ive been using double sided sticky tape for the longest time ever and I hate it......thanks again..I never would of taught if that...
Old Jan 20, 2013 | 09:30 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
You do Realise the gas tank in under the hump so i'd be very carefull IF It was me. I would or I did mount my amp in the spare tire compartment.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
