Custom Sub Boxes/System
Old Feb 11, 2013 | 09:29 AM
S_Johnson's Avatar
Car: 87 T/A
Engine: 400SBC Carb'd
Transmission: T56, Kevlar clutch
Axle/Gears: 3.73 Yukon Duragrip posi
I recently built my own sub boxes (10") for my Trans, and figured I should share.
It's not how many people do it, but I wanted more of a "bass guitar" feeling, and less of a "doorjam rattler" feeling
I also built these, so they can be easily moved down into the cargo, or backseat area, when I'm hauling lumber, etc...
I've also rotated the amp 90 degrees since I took these pictures, to be able to adjust the settings easily.
Attached Thumbnails Custom Sub Boxes/System-img_0079.jpg   Custom Sub Boxes/System-img_0081.jpg   Custom Sub Boxes/System-img_0082.jpg
Old Feb 17, 2013 | 01:14 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: Custom Sub Boxes/System
Your boxes look REALLY small for the size of speaker you are running. Speakers need air in order to move effectively and those boxes look way too small. How do they sound?
Old Feb 17, 2013 | 01:59 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Hauling lumber? Well I can't say I haven't seen it before but I guess you gotta do, what you gotta do. Just a little tip that may help how it sounds. Try turning the speakers around so the are facing the rear window. I messed with something similar to your setup on my old 97 RS in high school. Bass seemed a little deeper with them facing backwards, but still had plenty of punch. It was all just residual vibrations but still sounded good.
Old Feb 17, 2013 | 05:47 PM
S_Johnson's Avatar
Car: 87 T/A
A: Actually they are only a little smaller than the subs call for. They are the "Shallow mount" subs pioneer makes, and they are also designed for a much smaller box.
B: They actually sound GREAT. Much better than before (I used to have them in a larger shared box, that just pointed straight up.) They have a much larger range, not just "doorjam rattling."
Old Feb 19, 2013 | 12:18 PM
snake10566's Avatar
Car: 1990 Trans Am
Engine: Ramjet 350
Transmission: 5 Speed
Wow man, that is some nice work. I like the low profile speakers. Saves a lot of room in there. I have a sub box in my 90 bird, and it takes up the entire deepend part of the trunk and weighs about 80 lbs... Life choices are not always so good haha. But it gives me a bit more rear traction haha.
Old Feb 19, 2013 | 12:19 PM
snake10566's Avatar
Car: 1990 Trans Am
Engine: Ramjet 350
Also... are those stock seats in the back? They look pretty nice.
Old Feb 19, 2013 | 12:40 PM
S_Johnson's Avatar
Car: 87 T/A
Thanks!
My seats (all of them) are 4th gen seats our of a 2002 Trans Am.
They are 100% direct bolt in, no modifications.
(although, they had some extra features I didn't wire up, like air-powered lumbar adjustment. I could have, I just didn't care)
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
dusterbd
Sep 29, 2015 08:40 AM
