3" antenna
Old Jun 13, 2013 | 09:29 AM
jjohnston's Avatar
Car: 91 Camaro RS
3" antenna
Anybody know if the 3" antennas work as well as the tall factory ones? or do they look funny when on? I thought about deleting my antenna all together and figuring out how to hid it or something, but I don't want to repaint the whole fender to do that...
http://www.ebay.com/itm/310687513245...84.m1423.l2649
Old Jun 13, 2013 | 11:24 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: 3" antenna
It will not work as well. To see if you like the look simply take your stock one off, pop the ball off with some pliers(be easy as to not grab it to hard and bust it). I usually take the pliers and "pop it" from underneath the ball and it will come off.
Then just hacksaw it to the length you want and put the ball back on, touch up with black spray paint and bam...done.
Old Jun 21, 2013 | 02:55 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Re: 3" antenna
I've got one of those on my Iroc and my Tacoma.
Reception is degraded some but it looks cool, chicks dig it and who really listens to radio anymore anyways.
Old Jun 23, 2013 | 01:05 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: 3" antenna
The others are right. The factory length is considered the "Ideal length". That said, it also depends on where you live and drive. If you are in an area where you are closer to the stations you listen to, then you will not notice the weaker signal. I am deleting and shaving the antenna on my IROC, as I consider that to be the ugliest thing on the car. I'm going to put a hidden antenna under the dash pad.
Good luck, either way.
Old Jul 22, 2013 | 11:34 AM
theBIRD2445's Avatar
Car: 1991 Firebird Formula
Axle/Gears: 2:73
Re: 3" antenna
I just painted a nut with a round top on it black and screwed it on where the antenna goes. Looks just like a power antenna, costs basically nothing. And i still get okay reception.
Old Jul 22, 2013 | 03:49 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: 3" antenna
I have a three on mine and pick up fairly good reception. Like the others have said, depends where you are at and how strong a signal is.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
scottmoyer
Sep 7, 2015 07:06 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
