New Speaker Advice / Recommendations
Old Nov 6, 2013 | 09:45 AM
z28v8's Avatar
Car: 1987 IROC-Z
ok boys and girls, I'm looking for new speakers to replace my original 4x6s and 6x9s in my 87 IROC. I searched this site but didn't find the info I was looking for.
Anyway, I currently have a stock radio/cass. I might be upgrading that later but not yet sure. If I do upgrade, it will not be anything high-end or high-amp.
I'm just looking for good value, decent speakers that work well under normal conditions, fits without mods... nothing real loud... no amps, subs, boxes, or anything out of the ordinary is in the future of this car.
Cheers and thanks
Jeff ~
Old Nov 6, 2013 | 06:51 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: New Speaker Advice / Recommendations
You can still get the stock 4x6s and 6x9s if your not upgrading.
Old Feb 28, 2014 | 03:34 AM
Cameron@LFM's Avatar
IMO, browse ebay for an aftermarket 2 channel amp. Plenty of places to hide them in 3rd gens. Aftermarket 6x9's sound like garbage when they are underpowered from factory head unit. Not a hard install, just take your time running the wire.
Old Feb 28, 2014 | 01:47 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I have used kenwood decks and 4 channel amps and infinity kappa speakers since the 80s and I still do.
Old Mar 1, 2014 | 08:37 AM
Partspuller's Avatar
One way to pick up some nice speakers ridiculously cheap is to search through the high end import cars at the Pull-A-Part yard. Prices where I live are just over seven dollars each, so the last time I went I grabbed four 4" speakers from the door pods of a Lexus. If you want aftermarket brands look for modded tuner cars. I've gotten Polk 6x9's and Eclipse 5x7's recently that way.
If you're uncomfortable buying used stuff Ebay or Amazon would be your best bet. I have always liked the durability of Kenwood speakers and later if you want to upgrade head units Kenwood Epsilon series has lots of features and will make your speakers scream. You can grab a lower end model for not much over one hundred dollars.
Old Mar 1, 2014 | 08:46 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Cheers and thanks
Jeff ~
You should redo your search as this has been discussed MANY times
Top choices seem to be Pioneer, Infinity, JBL and Kenwood
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
jaridjohn
Oct 5, 2015 07:01 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
