What else can I use for a remote wire.
Old Sep 11, 2000 | 07:54 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
For some reason my remote wire is dead. Perhaps it got crossed with the amp power wire and got few 12 volts of power. Could this have fried something in the head unit with out affecting anything else. The head unit works on all 4 channels etc.
Anyway what can I use as a remote wire now? I really miss the bass.
Old Sep 11, 2000 | 08:23 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Sometimes you can use the power antenna wire. This wire and the amp wire is use just to supply a 12v turn on signal. They cant be used to power anything. Most are rated under 1 amp.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/15/00)
There can be only one!!
Old Sep 11, 2000 | 08:24 PM
rd44bb's Avatar
Just find a lead in the fuse box and test it too see if it turns on and off with the ignition, this should work, someone say if this is wrong.
88 Olds toronado trofeo 3.8. Black with gray leather
It's a 305 with the last two cylinders cut off...
hehe
165 H.P.
215 lb/ft Torque
Pioneer DEH-46DH
Pioneer TS-A6969
Stock "Dimensional Sound" Seperates up front.
My Trofeo Site
realdeal44 on AIM!
Old Sep 13, 2000 | 01:21 AM
klownDevilBoy's Avatar
i'm guessing you mean you fried the one from your stereo? if so you could either connect it to the ign. wire running to your stereo or run it to the radio fuse.
kDB
'88 Formula 350
w/ (3) JLAudio 10w6's on a Rockford Fosgate BD1000 @ 1 OHM
Old Sep 13, 2000 | 02:16 AM
Running it off the ignition will work, however note that the amps will be on whenever the ignition is on. If you turn off you radio for whatever reason, the amps will remain on until you shut the car off. Also, if running off ignition, you amps wont turn on when your switched to accessory.
-Justin-
Old Sep 13, 2000 | 04:22 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
yeah if ou connect something to your deck's remote wire that draws too much juice youll kill the turn on circuit in the deck.. for a remote to your amp you can use any 12v+ source.. i dont even use my remote turn on lead.. instead i run a wire from a switched 12v source in the fuse panel, to a switch, then to the amp.. the switch gives you control of turning your subs on and off at will.. nice for if you see a cop in town late at night, you can kill the noise and keep listening to the music.. heheh
Old Sep 13, 2000 | 08:22 PM
supervillin89's Avatar
find a constant 12v at the ignition harness, run a small guage wire from it to a relay, have a little switch using a ground or a 12v to flip on the relay, and ur good to go, also cood save ur *** if u get pulled over, and dont need a disturbing the peace ticket at 3AM. click, no officer, i dont have 1 of those loud offensive cars!
89 formula(LO3), 2" drop, basically the car where creativity, and installer skillz meet! "save a tree, eat a beaver!"
1992Z28!
Nov 19, 2015 07:33 AM
Thaney9
Oct 24, 2015 07:26 PM
tglennon11
Sep 23, 2015 05:30 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
FormulasOnly
Sep 10, 2015 09:07 PM
