Best place to mount an AMP
Old Sep 14, 2000 | 10:29 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Where is the best place to mount an amp? I am have small dinky amp now... and I kind of wedged it up just behind the passenger side part of the dash.... Was just wondering where you all put your amps.
Old Sep 15, 2000 | 01:55 PM
myposcamaro's Avatar
yo, do you have a trunk well lid that locks? if so i mounted mine on the underside of the lid cuz its lockable, and out of site. ive also seen people carve into theyre back seats and mount the amps so theyre flush against the gas tank and the seat fully locks into place. ive got a friend that mounted one in the little lockable tool box, and one where the spare tire goes, theres mad places, just gotta think
i have a p.o.s. camaro
Old Sep 15, 2000 | 08:40 PM
Topgun's Avatar
But my question is, dosn't the amp need air flow to cool the amp? Mine is just sitting on the gas tank next to the sub. That way in can get sufficent air flow. I will be putting dark tinting on the hatch so you can't see them and it will keep the sun from beating down on the amp causing it to get hotter.
EMAIL: CTopgun5@aol.com
_______
84' Z28
New 350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
160º Thermostat
K&N High Flow Filter
700R4 Trans
15X7 Standard Z28 Wheels, With 215/65R15 BF Goodrich Comp T/A HR4 Tires
Charcol in Color
no T-tops, but wish
New Head unit, JVC KD-SX750
New Kenwood 3-Way 6X9's
New Pioneer Sub
New Jensen 4-Channel Amp
As FiremanZ28 says "Friends don't let Friends Drive Mustangs"
Pic of my Z28, thanks to ZZ4 and his web page: Http://www.geocities.com/ukzz4iroc/z28camaro.jpg
Old Sep 17, 2000 | 12:39 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
I'm one of the guys that carved my back seat. It looks cool and leaves me a bit more space since my amp is out of the way. I mounted it as high as possible so it gets max. airflow and there's enough gap between it and the gas tank that the carpet doesn't melt. It works great.
Take 'er easy, and if
she's easy, take 'er twice!!!
Old Sep 17, 2000 | 01:43 PM
admrlam's Avatar
Im with hummer, i have three amps and a crossonver mounted in my seat. If im alone, i just keep the seat folded down, but even with them up, they dont overheat. Only had that happen once, and it was a five hour drive with the system goin FULL TILT, and i was late august, real hot. Plus the carved seat looks killer for the install. Heres a pic:
1988 Formula, 305TPI, 700r4(for now), headers, stage 2 PROM, modded MAF, cat back, no catalytics, cowl hood, centerline champ 500 rims, KOBEL predator ground effects kit, Trans AM tailights, dash pouch, 92 shift console w/indicator, white face gauges, accented red trim, 12 speaker stereo, 4 amps, tint, T tops... icq 44373460 AIM:admrlam
see it at www.geocities.com/admrlam/bird.html
Hotrodboba400
Dec 10, 2019 07:07 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
