SUBS????
Old Sep 22, 2000 | 08:56 AM
MR. JORDAN's Avatar
SUBS????
I HAVE 2 PHEONIX GOLD 12" COMP. SUBS IN MY FIREBIRD, BUT THET ARE IN A SMALL BOX IN MY HATCH AREA.THEY SOUND VERY GOOD RIGHT NOW WITH THAT SETUP. WOLD IT BE BETTER TO INSTALL A SUB PLATE TO CLEAN THINS UP A BIT
OR WOULD THAT SCREW WITH MY SOUND??
Old Sep 22, 2000 | 09:57 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You mean use a plate instead of a box? Plate's suck.
If you mean a plate over the box, then it depends. You could put the box in the well with the subs facing up, and use a plate with the holes cut out as a flush-mount with grills or something else over the holes to allow the bass to pass and that would be ok. But, if you just mean throw a slab o' wood over the box, that will block the sound.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 22, 2000 | 03:24 PM
MR. JORDAN's Avatar
yeah, i was talking about replacing my box with one of those plates that create a big box with your trunk area. would i lose sound or even worse my killer base?????
Old Sep 22, 2000 | 04:39 PM
Jim85IROC's Avatar
Plates suck. Going from a box to a plate is like trading a 2000 Camaro SS in for a Cavalier.
The IROC Homepage
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
efiguy
Sep 27, 2015 01:30 PM
