Strangest thing I've ever seen
Old Apr 21, 2014 | 10:53 PM
Eric Brumley's Avatar
Car: 1987 GTA
Transmission: TH700R4
Axle/Gears: 3.23 posi
I've never seen or heard of a stock car radio (or any radio for that matter) doing this. I own an 87 GTA. Completely stock radio (AM/FM with EQ and cassette). I was riding down the road with the radio on and hit a few potholes (nothing major). At first it seemed like the radio skipped a few stations or something hit the tuner button (it has no *****, just buttons). Nope. It started, on its own, moving through the stations/frequencies on the dial. No change to the digital screen or anything else. It does this once in a while. I can not reproduce it and when it does it, there isn't anything I can do to correct it.
Any ideas?
Old Apr 21, 2014 | 11:19 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Strangest thing I've ever seen
probably has some broken solder joints on the circuit boards-a common problem and an easy fix if you are used to radio repair.
Old Apr 24, 2014 | 11:24 PM
*84TA's Avatar
Car: 84 Trans Am
I second that. Cold solder joints! If you pull the radio, and take it apart post pictures. I can show you where to start re-soldering. You should probably replace the filter caps on the amp board when it is apart. A good tune up and you should get another 27 yrs out of it no problem.
Old May 12, 2014 | 09:37 PM
bbc632's Avatar
Car: 1990 z
Engine: 383 small block chevy
Transmission: tko 600
Axle/Gears: strange dana 60 4:10
Cord solder is the right way togo
Old May 12, 2014 | 11:02 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Man thats pretty cool to offer this for him...
Old May 22, 2014 | 08:01 AM
jdreswick's Avatar
Car: 1986 Trans Am
Engine: 327 .030 over sbc
Transmission: wc t5
Axle/Gears: stock
Any ideas?
Mine does this too! its sooooo weird. it will work fine then all of a sudden (on a smooth road) just cut out or start going through the stations. im confused and will probably send too get fixed cause im nat an electronics guy.
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
