Audio Questions
Old May 3, 2014 | 09:54 PM
ewagner93's Avatar
Car: 86 Trans Am Firebird
Engine: 5.0 V8 FI
Audio Questions
I'm trying to find a place to mount an amp in the back of my Firebird. As of right now, I have a custom box for the 12's taking up all the room back there. I was told not to drill down into the hump due to the gas tank being right underneath but I'm running out of ideas. The car is stripped down to bare metal so I can't even do something like velcro not that I ever would. Any help or a point in the right direction would be appreciated.
Old May 4, 2014 | 07:26 AM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: Audio Questions
3M two sided tape.
Old May 4, 2014 | 08:30 AM
1tuffTA's Avatar
Car: 1987 Trans Am
Engine: 383 stroker, Holly650,MSD
Transmission: TH350
Axle/Gears: 3.23posi/wdisc
Re: Audio Questions
What I did in my car was, I cut a piece of 5/8 plywood I had lying around to the dimensions of the rear well floor (with carpet) then bolted the amp to the plywood, wedging the plywood into the carpet kept the amp solidly placed. The only problem I had the sub box closed off the rear well and the amp would over heat and the thermal switch would trip, so I got me one of those small cooling fans for a computer tower and built a bracket for it so the fan could blow air across the amp and no matter what the amp wouldn't over heat.
Now I'm in the process of removing all the aftermarket stuff to put my car back to factory original...my "thump thump" days are over lol!
Old May 5, 2014 | 09:00 AM
devestator_x's Avatar
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Re: Audio Questions
How about in the spare tire well, or the locking box on the drivers side? There is typically enough ventilation to stop any overheating issues.
Old May 5, 2014 | 11:11 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: Audio Questions
i agree, i would think this would be better than in the direct sun all the time
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
