Antenna route and grounding for signal
Old May 5, 2014 | 10:54 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I have marine FM antenna I bought form local audio shop. it seems thin and flimsy. I plugged it into my pioneer HU and ran it up under the dash and up the passenger a pillar.
That gives ok reception. Anywhere else it is horrible or way too much RF noise. Anyone have luck with strong route? Can I just ground to something? Can I run AWG wire instead?
The stock antenna is still installed to the electric passenger motor but I was planning on removing. Can I just remove the motor and block off antenna hole in fender and leave stock wire in firewall with decent results?
Maybe just use the stock F plug form the OEM wire, cut it off and run AWG somewhere.
Old May 5, 2014 | 11:14 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: Antenna route and grounding for signal
anywhere inside the car is not going to work that well, unless you are real close to the stations transmitter
Hotrodboba400
Dec 10, 2019 07:07 PM
Fronzizzle
Feb 9, 2017 09:31 AM
gta892000
Sep 16, 2015 12:37 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
