Pioneer 1.5 din HU and wiring harness problems...Please help!
I just recieved my new pioneer HU today, it is the DEH-P77DH. I also ordered a wiring harness (pioneer brand RD-GM78). I got these both from autotoys.com and it said this was the right harness for my 86' T/A. The harness I recieved even said it fit 77-89 firebirds/camaros on the box. When I went to install it the plugs are not compatable. My stock plugs are a set of three plugs (black, blue and clear) that plug vertically into my tape deck. There is also a plug that connects for power (black). The wiring harness consists of two wide plugs with pins (black with 7 pins and grey with 5 pins). The stock plugs do not even use pins at all. Please help! Is there a harness that will connect to the system I have described? Has anyone else installed a 1.5 din pioneer hu? Did you have the same problem? Thanks!
"T/A all the way"
"T/A all the way"
Yes, there is a harness for you. fits all Camaros/Firbirds for those years. Just go to any place that sells Car Audio. Take a look around, look at the harness and you will find what ones will fit. Pay no attention to what the box says. I found that out myself. The box said that it would not fit my car but infact it did! Though i chose not to use a harness. I just wired my head unit without the harness. Hope this helps
EMAIL: CTopgun5@aol.com
_______
84' Z28
New 350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
160º Thermostat
K&N High Flow Filter
700R4 Trans
15X7 Standard Z28 Wheels, With 215/65R15 BF Goodrich Comp T/A HR4 Tires
Charcol in Color
no T-tops, but wish
New Head unit, JVC KD-SX750
New Kenwood 3-Way 6X9's KFC-6906S
New Pioneer Sub TS-W253C
New Jensen 4-Channel Amp XA-4150
As FiremanZ28 says "Friends don't let Friends Drive Mustangs"
Pic of my Z28, thanks to ZZ4 and his web page: Http://www.geocities.com/ukzz4iroc/z28camaro.jpg
_______
84' Z28
4 BBl Carb
160º Thermostat
700R4 Trans
Charcol in Color
no T-tops, but wish
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Does the harness look like the one they have pictured on autotoys.com? I took a look and it looks like it should fit. The black part should have 12 male connectors that plug into your harness which should have female connectors.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
[This message has been edited by Justins86bird (edited October 16, 2000).]
-Justin-
Car: 1998 Camaro Z28
Black86TA,
I used the Metra brand that Circuit City sells when I installed the Pioneer77DH in my 1991 Camaro. The part# is 70-1858. GM 1988 and up (21 pin). I think it was $14. Try Circuit city and asked for pre 1988.
HTP!
Matt
HTP!
Matt
The pic at autotoys is not the same one that I recieved. I'm gonna go out to to a car audio shop tonight and get the one I need. I hope I can return my old one. That would be a waste of $20. Thanks!
"T/A all the way"
"T/A all the way"
Someone prolly switch what was supposed to be in the package. Places are always pulling that ****. Most places will carry the generic one which one end plugs into the cars harness and the other end splices into the decks harness.
-Justin-
-Justin-
