Pontiac radio problem
Car: 1987 Trans Am
Engine: 383 stroker, Holly650,MSD
Transmission: TH350
Axle/Gears: 3.23posi/wdisc
I have a Pontiac UX1 radio with no front left channel...I added a Mp3 aux. input, could this be the problem?...all wiring connections were properly soldered and insulated with heat shrink tubing. For me hacking in an aux. jack is one thing, but electronic circuitry is beyond me...Thanks!
Car: 1987 Trans Am
Transmission: TH350
Re: Pontiac radio problem
...45 views and not one reply...obviously this was the wrong place to go with a Pontiac radio problem! Joined: Jul 2011
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Assuming you're not running an amp, swap a working channel with this channel to determine if the problem is inside the radio or not. If swapping wires still has the LF speaker inop, the problem is in the wiring. If swapping wires causes the swapped speaker to be inop, the problem is in the radio.
Edit to add:
you have to swap wires at the radio connector for this test to work.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I imagine that anything you modified in an aux conversion would take out the whole side and not just the left front. Any links to where you found the instructions? It might help people see what and where you made the modifications. I've seen a couple of ways of doing it.
Sometimes the output transistors go out as well. I also agree with what Lurbie posted.
FWIW, Pontiac vs. Chevy doesn't really mater as much as the version/model of the radio you have. Differences between them are more in the face plates than the electronics inside.
Car: 84 Trans Am
Was the radio working properly before you added the aux jack? Did you have power applied to the radio during or after the modification before you reinstalled it in the car? If it just the front left channel and not the front and rear I can say with certainty that it is a bad output IC. They can be replaced. You need a good quality thru-hole vacuum desoldering gun to take out the old one.
colton_carlson
Mar 8, 2019 12:21 PM
