Sub Hook up Question
Old Oct 31, 2000 | 11:34 AM
Vortex_89rs's Avatar
Okay, i just got two 10's in a box, and was wondering how to hook them up. I have to go get an amp today - what should I get? A 200watt? One 10 is a Rockford Fosgate and the other is an MTX. My stereo has front and rear RCA preouts. Now, should I hook the amp up to the rear preouts, and then hook the speakers into the amp, and run power back to the amp? How should I do it? And how big should the power wires for the amp be?
Thanks for any help
Vman
1989 Camaro RS
2.8 V6
K&N's
700R4 tranny
Cragar Street Pro rims (old Series 30)
Pioneer DEH-P3000
1969 Camaro SC
350 HO from a Vette
Turbo 350 tranny
In the process of being restored
Old Oct 31, 2000 | 12:19 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You're not going to want my opinion, but here it is. Pick one sub or the other. Mixing different subs sucks. It sounds bad, and sometimes won't hit as hard as just 1. After you pick a sub, follow the bridging instructions for the amplifier and you'll be all set.
The rest of your questions can be answered by the car audio articles in the "Technical Articles" section of this website.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 31, 2000 | 01:07 PM
Matt Finch's Avatar
Car: 1982 Trans Am
Transmission: Turbo 350
Axle/Gears: 3.23:1
I agree. Mixing two different types of subs does not only sound bad, but it can be bad for your amp if you run them in 2 ohms mono. I would suggest picking the best out of the two, selling the other one installing it using good 11 guage speaker wire and 8 guage for your amps. DO NOT CHEAP OUT ON WIRE (especially RCA's)! IF you have anymore questions e-mail me at Finch.fbody.com
Thanx!
Old Nov 1, 2000 | 04:37 AM
killrog22's Avatar
run rca's from the rear outs from your raido to your amp. run 12 guage speaker wire to your speakers from your amp. Because you have two different speakers, run two different amps. one briged amp per speaker. Get two small two channel amps, maybe 240 watt each. run 4 guage power wire two a splitter that will give you two 8 guage outs and run one to each amp. rember to run the same gauge wire for ground. If you run two amps, you will have to split your rca's with y connectors (one female in and two male out) so you can supply both your amps with a signal.
deracer
Apr 11, 2016 12:04 AM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
