Inside and out ...
Old Nov 12, 2000 | 01:13 AM
85IROCTPI's Avatar
Inside and out ...
I can't live without my music inside my car. However i spend alot of my time outside my car too (in the garage or driveway or whatever). I want to build a system using a pioneer oversize CD deck, 1 amp, and 2 10" Pioneer Subs in an enclosure (along with any other suggested equip) that will drop even the lowest bass lines inside my car, but that i can still hear outside my car. Also, what will i have to rubberize/soundproof/etc if i use your plans
Old Nov 13, 2000 | 12:06 PM
Chris Luongo's Avatar
If you open the rear hatch, you should be able to hear your rear 6x9s pretty well. If you have T-tops it should be even better.
Old Nov 13, 2000 | 03:59 PM
85IROCTPI's Avatar
Thats obvious, but i'm looking for bass, and you dont get alot of bass with the hatch open or t-tops out.
Old Nov 13, 2000 | 11:11 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
That's Bull****! I have an RS with t-tops, and when the are off AND the hatch open, it sounds just as good as if the car was all closed up.
Old Nov 13, 2000 | 11:15 PM
85IROCTPI's Avatar
Not in my car. Thats why, if you read my origional post, it asks what i would need to build a system capable of this. I dont have a system yet. Please read my origional post.
Old Nov 14, 2000 | 07:32 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
What kind of enclsoure are the subs in? Is it 100% sealed or is it ported? In either case, how well built/air tight is it? I've found that in most cases when you have bass inside but not outside it's because the box is swiss cheese and causes cancellation.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 14, 2000 | 10:34 AM
CHCKLS's Avatar
Engine: 409 SR
I apologize, but it sounded like you where making a statement in that you simply can not get bass with the tops off or the hatch open. There have been guys on here that say it can't be done with a convertible either, and that makes me laugh, so I apologize.
I understand exactly where you are coming from and wanting to hear the music as well when the car is in park and you are doing other things outside and what not.
All I have is one JL 10" sub in the rear that is enclosed and powered by one two channel alpine amp. My 4x6s and 6x9s are powered by a 4 channel alpine amp, then those amps come an alpine EQ and then from the cd deck itself. Very simple system and gives the amount of bass I want. Sounds just as good as inside with the car all closed up as it does when the t-tops are off and the hatch open.
The box is air tight, no doubt about that, and it all sits nice and snug in the rear trunk area along with the amps. The best part is that I still have a place to put my t-tops when on the road.....
HTH
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
KO1
16
Oct 15, 2015 05:00 PM
383backinblack
Oct 14, 2015 08:50 PM
