Sub Replacements for UQ7
Old Mar 20, 2015 | 02:00 PM
  #51
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
Re: Sub Replacements for UQ7
Originally Posted by t/aws61985
on my 86, the fronts are 16033662. The rears are 16031000. Not sure what ohms they are.
Those are the same speakers in my '84.
Old Mar 20, 2015 | 02:01 PM
  #52
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Man........did I open up a Sub Replacements for UQ7-can-worms-smiley-emoticon.gif !!!!
Old Mar 20, 2015 | 02:30 PM
  #53
I found these that seems to have a similar shape to the originals in my car but are 8 ohm impedance. I measured the originals and they had 7.7 ohm DC Resistance (10 ohm impedance). These have 8.11 ohm DC resistance so they might be OK to use with the factory amp.
GRS 4FR-8 Full-Range 4-1/2" Speaker Pioneer Type A11EC80-02F 8 Ohm
Going to order 2 and see how they compare to my repaired originals.
Old Mar 20, 2015 | 02:41 PM
  #54
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
OK, now you're talking about subs replacement, not 4x6
I seen the subs at PartsExpress. I just love the WARNING for Ca. Residents! Ha! See below
(BTW...I lived out there for 24 years, Edwards AFB/ California City)
California Prop 65
Warning: California residents only. Please note per Proposition 65 that this product may contain chemicals known to the State of California to cause cancer and birth defects or other reproductive harm.
So, I'd watch them if I were you!!!!!!!
Old Mar 20, 2015 | 02:53 PM
  #55
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
This is what's online today
Originally Posted by jaimegmr
What!?! I just tried ordering some online at various stores including Summit Racing and was told by all that they were now discontinued and were not available
Just checked gmpartsdirect.com and it also says they are discontinued.
One slight problem with that is that the original 4x6" speakers in the back are 4 ohm rather than 10 ohm like the fronts. With 10 ohm speakers in the back they wont be as loud so you'll have to play with the fader on your radio to balance the sound out.
I'm not sure about the Ohms either ,speakers are not marked.You can't tell the difference at all in the sound
Just realized that there are multiple setups used throughout the years and in your case 10 ohm speakers all around may be correct. You would have to measure your original speakers to verify. I made that statement based on my case.
In my 1984 Trans Am, the front speakers are the 10 ohm (16033662) speakers. The rear 4x6" speakers are 4 ohm and have a connector on the two wires.
My subwoofers are different from the ones shown previously in this thread. Mine are 4.5" subs (diameter measured from opposite areas between mounting holes). It appears that larger subs were used in later years.
Yes that's correct,85-88 used 5 1/4 round
Here are the subs I am repairing:
Note the inverted replacement foam surround. From what I read, being inverted should not matter.
That's correct
Originally Posted by Bob88GTA
Man........did I open up a Attachment 290190 !!!!
No you didn't,they are what they are.
Old Mar 20, 2015 | 04:32 PM
  #56
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I love the looks by the "younger guys" when I pull up at a stoplight and I'm in my Bronco or my 88 GTA, 1000 watts, thumping to Def Leppard!!
LMAO!
Now you're talking!
There is NEW Whitesnake out right now...have to give this a try this summer with the tops out.
Old Mar 20, 2015 | 05:07 PM
  #57
mantaguy's Avatar
Engine: 5.0 EFI
Sorry guys,I'm a 50s-60s and some 70s Oldies guy,Motown,Wall of Fame type
Old Mar 20, 2015 | 05:09 PM
  #58
DynoDave43's Avatar
I'm OK with that mantaguy. I like all kinds of different music.
Some CCR for you perhaps?
Old Mar 20, 2015 | 05:25 PM
  #59
mantaguy's Avatar
Engine: 5.0 EFI
Creedence is OK too
Old Mar 20, 2015 | 07:56 PM
  #60
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
We'll keep ya Manta, its cool!!!
Old Mar 20, 2015 | 08:30 PM
  #61
mantaguy's Avatar
Engine: 5.0 EFI
I just read that it's OK to go from a 4 ohm to 10,but not 10 to 4.
Here's one of the receipts from the GM Dealer, I can't find the last one witch would have been about year, year and a half ago.I bought them because the only difference was the pigtail wire in witch I bought the pigtails from member my82roc and soldered them onto the wire prongs.
Old Mar 22, 2015 | 11:39 AM
  #62
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Huh, 10 ohms ? That would be odd. Pretty sure they switched to 4 ohms in 1983 with the "newer" aqua color display radios (older were yellow/orange). And I think the later 2nd gens used 4 ohms too, but I don't know for sure.
I'm using 4 ohms all around in my '84 with the original UU6 unit, no problem at all.
Also the original front 4x6 and rear 6x9 speakers from my '89 parts car are 4 ohms, can't remember the part number though. I'm actually using the two front ones in my '84.
Old Mar 22, 2015 | 12:36 PM
  #63
mantaguy's Avatar
Engine: 5.0 EFI
I have a set of 6x9s out of a 88 TA and they are 4 ohms ans I also have the original front 4x6s and they are 10ohms.I was checking the 86 service manual for the speaker ohms but it's not listed,but the Sub switch (it shows that)should show 10,000 ohm resistence test(does that mean 10ohm?)
Old Mar 22, 2015 | 01:16 PM
  #64
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
. 10K is 10,000 ohms
Old Mar 22, 2015 | 01:34 PM
  #65
mantaguy's Avatar
Engine: 5.0 EFI
Thanks Bob,that's what I thought.I won a door prize(volt meter) at one of the car shows
Can I test the speakers for ohms out of the car? unplugged?
Old Mar 22, 2015 | 01:42 PM
  #66
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Yup, Just use the 10-20k ohm setting.
Old Mar 22, 2015 | 01:50 PM
  #67
mantaguy's Avatar
Engine: 5.0 EFI
OK,I checked all the speakers,Front's Rears and Subs,they all read 0.01,does that mean 10,000 ohms ?
This is the setting I used.
Old Mar 22, 2015 | 01:59 PM
  #68
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
An 8-ohm speaker will read around 6.2 on the meter. This is completely normal.
10 OHM will also read a little less than 10, LIKE 8.5 ish.
If the speakers are out of the car and not connected, you should get a closer reading. And I know you have the power off if in the car. Try reversing the wires, you want Red on Pos and Black on ground, but you know that too!
Old Mar 22, 2015 | 02:05 PM
  #69
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
And round up like 3.5 is 4ohm, 8.6 is 10 14.5 is 16 and so on
Old Mar 22, 2015 | 02:13 PM
  #70
mantaguy's Avatar
Engine: 5.0 EFI
These speakers are out of the car.So the reading 0.01 is wrong?
What setting would I use for the 6x9s 4 Ohm Test?
Old Mar 22, 2015 | 02:34 PM
  #71
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
4 OHM TEST WOULD BE ON THE 200 SETTING, YOU SHOULD GET 3.6, 3.7 OR SO
sorry bout the caps.
Old Mar 22, 2015 | 02:35 PM
  #72
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
try the 8 ohm test on the 200 setting
Old Mar 22, 2015 | 02:41 PM
  #73
mantaguy's Avatar
Engine: 5.0 EFI
I'm getting 4.1,4.2 (switching wires) on the 200 setting of the 4 ohm speakers,I don't have any 8 ohms to test
Old Mar 22, 2015 | 02:45 PM
  #74
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
OK, you're good, 4ohm on 200 setting. What was you trying to find out?
Old Mar 22, 2015 | 02:49 PM
  #75
mantaguy's Avatar
Engine: 5.0 EFI
If this meter was working correctly.
Old Mar 22, 2015 | 02:54 PM
  #76
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
It's good. Stick some paper clips in a 120 volt outlet and grab hold of them. If it shocks you, take the clips out and insert the probes of the multimeter in on the 200 VOLTS setting, You should get like 110-125V. I am being really funny now on a rainy Sunday!
Old Mar 22, 2015 | 03:00 PM
  #77
mantaguy's Avatar
Engine: 5.0 EFI
,No Thanks,I'll take your word
Old Mar 22, 2015 | 03:07 PM
  #78
mantaguy's Avatar
Engine: 5.0 EFI
So we can safely say without doubt that 85-86 UQ7 Sound System uses only 10 ohm Speakers.
Old Mar 22, 2015 | 03:20 PM
  #79
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
[QUOTE=jaimegmr;5892795]Just realized that there are multiple setups used throughout the years and in your case 10 ohm speakers all around may be correct. You would have to measure your original speakers to verify. I made that statement based on my case.
I guess after reading through all of these post', I'm gonna haft to say yes, 10 ohm. I didn't measure ANY of mine, nor took the subs out yet. But by the way one of the subs look; the right side, it needs help. Half of the surround is gone but the cone is perfect. The repair kit should work well. I'll measure all of them when I take em out.
Old Mar 22, 2015 | 03:55 PM
  #80
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Another topic
Old Mar 22, 2015 | 04:03 PM
  #81
mantaguy's Avatar
Engine: 5.0 EFI
A little faded, but their still there.
Old Mar 22, 2015 | 04:09 PM
  #82
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Way too cool! Just checked the 89 TTA and nothing on them. My 88 GTA is down the street in storage so don't know about it. Was that an early year thing
Old Mar 22, 2015 | 04:13 PM
  #83
mantaguy's Avatar
Engine: 5.0 EFI
Don't know!I swear the 85s and 86s are Identical cars.
Old Mar 23, 2015 | 08:46 AM
  #84
mantaguy's Avatar
Engine: 5.0 EFI
I just got a email from GMPARTSDIRECT and their saying that the 4x6s are no longer available.Now, I'm wondering, is it just them,because I just bought 4 from my local Dealer not too long agoAre they just to lazy to order a set or what.
Old Mar 23, 2015 | 08:59 AM
  #85
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Yeah, I got one of those emails too. So........I am on a mission to find them!
Old Mar 23, 2015 | 04:10 PM
  #86
mantaguy's Avatar
Engine: 5.0 EFI
I'm going up to the GM Dealer that I got mine from tomorrow and check,I'll let you know.
Old Mar 23, 2015 | 04:36 PM
  #87
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Great, maybe you'll luck out! I got my sub repair kit today! YAY! Ordered on Thursday from California, quick trip. Now I have THAT to do! I need to retire so I can play. 13 to go!
Old Mar 23, 2015 | 04:46 PM
  #88
mantaguy's Avatar
Engine: 5.0 EFI
Wow,that was quick,good luck.
Old Mar 24, 2015 | 07:57 PM
  #89
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Are these the rear sub boxes and speakers you guys are chatting about?
Old Mar 24, 2015 | 08:07 PM
  #90
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Not being a smart a## here.
Well yes they are Mr. Helper, what's up?
Old Mar 24, 2015 | 09:39 PM
  #91
DynoDave43's Avatar
That's them. Nice photos too. Saved for reference.
Old Mar 24, 2015 | 09:58 PM
  #92
mantaguy's Avatar
Engine: 5.0 EFI
Pretty ingenuous for the 80s.
Old Mar 25, 2015 | 03:21 PM
  #93
mantaguy's Avatar
Engine: 5.0 EFI
Well it's Offical NO MORE AC DELCO Front 4X6s,
Old Mar 25, 2015 | 03:29 PM
  #94
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
BOOOOOOOOOOO!
Old Mar 25, 2015 | 03:36 PM
  #95
mantaguy's Avatar
Engine: 5.0 EFI
I'm glad I decided to do the radio when I did,I must have gotten them close to the last of them in inventory
Old Mar 25, 2015 | 06:47 PM
  #96
85FBTranam's Avatar
Surprising they fit in the B Pillar. I've got 6x9's in. Pulled these when the car was new.
Old Mar 25, 2015 | 07:17 PM
  #97
mantaguy's Avatar
Engine: 5.0 EFI
Were they stored properly and are they for sale??
Old Mar 25, 2015 | 07:28 PM
  #98
85FBTranam's Avatar
Perfect shape Manta. Have been stored indoor, heated and covered for 30 years. PM me, we can chat. Thanks.
Old Apr 28, 2016 | 11:23 AM
  #99
So to sum it up, what is the correct impedance for the UQ7 system speakers :
- front 4x6
- rear 4x6
- rear subwoofers
I'm trying to replace the subs and rear speakers but I have no idea what I should use.
The front ones are the factory ones from a 1989 model and still sound allright.
Old Apr 28, 2016 | 05:40 PM
  #100
85FBTranam's Avatar
I looked on the speakers, but no indication of the impedance on them.
