What Harness to get??
Old May 2, 2015 | 10:48 AM
Boots16's Avatar
Car: 1989 IROC Z
Transmission: 5 speed Manual
First off im a newbie here. I just bought an 89 Iroc and I want to know which wire harness to get to put in an aftermaket radio. I got 5 wire connections.
This is the closest i could find but it only has 4 connections
http://www.carid.com/scosche/car-ste...ct-details-tab
Thank You
Old May 4, 2015 | 12:59 AM
BK2FUTR's Avatar
Car: 1986 Chevrolet Camaro
Engine: V6 2.8L
Re: What Harness to get??
Hey Boots!
So Im just doing my stereo this month as well, I went on ebay and typed in "1986 camaro stereo wire harness" and so i got mine doing that. You are going to need a dash kit as well if you don't already have it, (the plastic trim around the stereo to make it fit in your dash) so i just got a bundle where they had the dash kit AND the wire harness together.
Here the ebay link to the one i bought, it says out of stock now, but you can take a peak !
http://www.ebay.com/itm/360595529407...A:1120&vxp=mtr
Regards,
Zubayr
Old May 7, 2015 | 05:14 PM
AmorgetRS's Avatar
Boots16 - the one you posted looks like the right one. You can probably find it a lot cheaper on Ebay
Old Aug 31, 2015 | 12:00 AM
SlowAZ28's Avatar
Car: 1992 Camaro Z28
Engine: 5.7l TPI
If you're still searching for an answer to this post, may I suggest metraonline.com You can search by your make and model and it will give you the correct model number for your application. The harness you're looking for will start with a "70-". I've found metra harnesses are higher quality than the schose brand you'll find at Walmart or eBay. Most of the harnesses are color coded the same as the back of the aftermarket deck so you simply match the colors and then plug it in.
Old Sep 30, 2015 | 04:42 PM
MintWS6FORMULA's Avatar
From: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
Thank You
That's why I shop at crutchfield.com. They'll send the correct connector you need for your car right along with your radio.
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
efiguy
Sep 27, 2015 01:30 PM
