Need Some Advice
Old Dec 9, 2000 | 04:55 AM
1989CamaroRs's Avatar
Need Some Advice
I have some Polk Dx9 6x9s comming in the mail, and i plan on getting a sub. So is much bass really need in the front of the car. Would 4 inch speakers in the bose system location sound good, with tweeters on the dash or door? Or my other option is to build a door panel speaker box with a 5 1/4 or 6 1/2 inch speaker if its really necessary. Opinions?
Edelbrock TES Headers, High Flow Cat, Edelbrock Catback, SSM Subframe Connectors
Old Dec 9, 2000 | 06:49 AM
camaro 22's Avatar
it depends on how much base you want really. will you be running an amp with your sub or other speakers? how about your deck? are you using a sealed enclosure with your sub? all these things play a role in a good system. but it's really a personal preferance though on how much base is desired. installing better speakers in the stock locations is definantly a noticable improvement though.
Old Dec 10, 2000 | 09:38 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Bass is omnidirectional....in other words it doesnt matter where the subs are located at it will sound the same within a given space. The Bose accoustimass system is a good example. With that said you can put your subs anywhere in the car. Besides, it would be difficult if not impossible to put good bass speakers in front.
92 Camaro RS LO3, 5-spd, T-tops
Mechanics:
Open Air Element w/K&N Filter, Flowmaster 3" Cat-back Exhaust, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-90 Amps powering 2 12" Pro Red subs and 4 Infiniti speakers.
NEXT UP: SLP 1 3/4" Headers/Y-pipe, Centerforce Dual Friction Clutch kit
Old Dec 10, 2000 | 04:20 PM
ok then if im going to get 4 inch componet speakers would it really matter if the woofer is mounted in the dash or in the bose location?
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
