Have a question about noise?
Old Nov 22, 2000 | 06:47 PM
Sweet_85_Bird's Avatar
When i press the as i get a really loud *** whine.
How do i get rid of it?
Old Nov 30, 2000 | 10:42 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I take it you mean press the gas? You didn't say what your stereo system has... could be that you need a noise filter (which I've never had work) or that there's some ground problem somewhere...
Or maybe your spark plug wires are worn out!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 30, 2000 | 02:41 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Your first thing should be to re-ground your amp(s) to a common point and do it properly, as described in other various posts. 99% of the time that will help. If that doesn't help, then you either have a fairly serious problem, or extremely cheap equipment, both of which obviously need to be dealt with differently.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Dec 11, 2000 | 03:08 PM
85berlinetta's Avatar
If you are using an amp, Radio Shack has noise filters for this. They run at around $20.00.
Old Dec 11, 2000 | 06:40 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Another area that causes trouble is the RCA,s. If they aren't shielded or if they are too close to your power wires or sometimes even things like computers,digital clocks,etc.,that will introduce noise into the sytem also.But,as said before,I would check your ground(s) first and then,if that doesn't help,re-route your signal and power cables.
Old Dec 11, 2000 | 06:59 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
I have the same problem sometimes. I did the install myself (quit laughing)
anyway, when the ground and positive cable get wound up, or they sit too close side by side, then i have the same problem.
I would say before buying anything, to make sure your positive and negative cables are tight in their sets, and to make sure the wires dont cross over eachother at any point.
cured my problem
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
redmaroz
Aug 16, 2015 11:40 PM
BlackBoulder
Aug 11, 2015 11:15 PM
