sub woofer question
Old Jun 27, 2016 | 02:06 PM
fbodyguy86's Avatar
Car: 92 camaro rs
sub woofer question
i have a soundstream xta600.5 amplifier. it is a 5 channel amp the 5th channel for the subs is rated at 1x120 4ohm stereo, or 1x240 2ohm stereo, or 1x240 4ohm bridged. i am looking at getting new subs for it would i want to go with a dual 4ohm voice coil or a dual 2ohm voice coil or a single voice coil
thanks
george
Old Jun 27, 2016 | 06:09 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: sub woofer question
dual 2 ohm in parallel is 1 ohm... too low, could damage amp.
dual 2 ohm in series is 4 ohm.. works fine.
dual 4 ohm in parallel is 2 ohms... works fine.
dual 4 ohm in series is 8 ohms... too high, poor output.
Old Jun 28, 2016 | 11:27 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
A bit confusing...
You stated the 5th Channel (1 channel)... stereo signal being run into 1 / mono signal.
Then you stated your options...
First 2 options make sense, but option 3... You need another channel to "bridge" it.... so is the 5th channel 1 single channel or 2 (6th channel)???
If it's one single, go with 1 dual 4 ohm voice coils, wire them in parallel @ 2ohm's and 240 watts...
Old Jul 10, 2016 | 08:47 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
thanks
george
DO you want one or two subs?
240 w is not a lot of power for two subs.
T_P_S
Jul 11, 2016 05:05 PM
Hawkeye1980
Car Audio
Jun 30, 2016 12:35 AM
thomashearts
Jun 26, 2016 08:46 PM
goalieforlife
Car Audio
Jun 25, 2016 09:28 PM
seanof30306
Jun 9, 2016 06:48 AM
