UQ7 Question any help would he awsome
Old Mar 19, 2017 | 03:10 PM
bulett289's Avatar
Ok so digging into my 1988 formula i found out it has the complete UQ7 Harness gain control and amp but apeaker enclosures are gobe and wires have been cut ...... posting pictures of the wiring mess i am contending with anyine that can tell me what us what would be awsome . Thanks for any help you may be able to give.... Azsuming main power harness
Big harness with 2 seperate plugged into it.
Then 8 wires off that harness and 4 wires matching rear speakers comes from inside dash.
Pink wire runs up behind instrument panel.
8 wires off harness and 4 wires from under dash
Driver rear yellow and brown and liggt blue dark blue cut and tucked behind plastic panel.
DRk blue light blue with another dark and light wire cut behind plastic.....
Old Mar 20, 2017 | 03:34 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: UQ7 Question any help would he awsome
This link will take you to page 3 of my cars thread, which IDs the amp. There's also info further on about replacing the foam surround on the UQ7 speakers, if that would help.
https://www.thirdgen.org/forums/memb...ml#post5901182
