Amps?
Old Jan 1, 2002 | 04:04 PM
The Man Metz's Avatar
Amps?
Ok i was lookin at a Kenwood 300watt amp that was rated at 100x2 @ 14.4 volts and i was lookin at a US Acoustics 300watt amp that was rated at 100x2 @ 12.9 volts. I was wondering if the amp with the lower input voltage (12.9) would put out more power than the amp with 14.4 input volts. Will the amp with 12.9 put out alot more power than the one with 14.4 volts? Also for example if the battery is putting out 13.8 volts will the amp with the 12.9 volt rating put out more than 300 watts and the amp with the 14.4 rating will it put out less than 300 watts?
Old Jan 1, 2002 | 04:29 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
the amp with 12.9v rating will *probably* put out more wattage at 14.4v. All of the more expensive brands, such as mtx, rockford fosgate, kicker, etc, put out more wattage at a higher voltage. the reason why the US Acoustics amp was rated at 14.4v is because that is the least amount of voltage it requires to get the 100x2 watt rating. the US Acoustics probably puts out more like 75-80 watts per channel when in 12.9, but dont qoute me on that.
Old Jan 6, 2002 | 09:21 PM
Thanks for the input is there anyone else that would like to add? I could use all the info i could get
Old Jan 7, 2002 | 01:36 AM
Mike92RS's Avatar
An amp with a loosely regulated or unregulated power supply will generally put out more power at a higher voltage.
- Mike
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
