Factory radio specs
Old Apr 29, 2018 | 05:36 PM
Nick Gallegos's Avatar
Car: 1986 Camaro Z28
Engine: Lb9 305 Tuned Port Injection
Transmission: 700-r4
Factory radio specs
I have looked everywhere for specs on my factory delco/bose radio (rpo YE2) on my 86 z28 and i can't find anything.i want to know how many watts it could make because i am replacing all the speakers and putting an amplifier in it, And if the radio can produce enough wattage for the front speakers i can just have an amp for the rear's.
Old Apr 30, 2018 | 01:07 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Factory radio specs
you will need an amp for the fronts-radio output with the Bose is ~1/10 watt or less.
Old May 2, 2018 | 06:22 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Don't the Bose/Delco radios have a amp built/attached in each speaker already?
Old May 4, 2018 | 11:29 PM
The fronts just looked like regular speakers and the rears were replaced at some point with sony's and had a very bad wiring job.
Old May 6, 2018 | 08:08 AM
A sine wave, 12 volts peak-to-peak, into 8 ohms, no distortion (i.e. no clipping of the waveform), both sides driven (i.e. neither speaker lead grounded: at any given instant, if one side of the speaker is being driven positive, the other is being driven equally negative), is around 3 - 3½ watts.
Factory radios were designed to drive 8 - 10 ohm speakers; but most replacements are 4 ohms. Some are only 2 ohms.
This is the approximate audio equivalent of plugging a 40 amp welder into a 20 amp circuit. Although, in the case of audio, it won't usually blow a breaker or damage anything (it might, but not usually); what it will do instead is, sound like crap esp at high volume, and not get as loud as it should.
I would recommend an amp for any aftermarket speakers behind a factory radio, no matter how much/little the radio might have been "rated" for, if for no other reason besides the impedance mismatch.
gmwheelz
Oct 4, 2012 09:49 PM
lugnut87
Interior Parts Wanted
Apr 4, 2011 12:23 PM
Justin 87 GTA
Jan 22, 2004 06:45 PM
