Constant power on radio plug doesn't work
Old Jul 3, 2018 | 08:35 PM
iosigma's Avatar
Car: 2017 Jeep Cherokee
Transmission: 6 Speed, 5 Speed T-5
Ok guys, I am installing a stereo in my 1991 Camaro RS. I just installed a Dakota Digital Dash (which works great btw). I was going through the factory radio plug to get the power wires hooked up for my new install. I used a test light and check the plug, theres no constant power to the wire thats supposed to be constant. I checked all the wires in the plug thats supposed to have power. When the car is off theres is no power at all. When the car is on, the accessory power wire has current. I have checked the fuses at the fuse block and all are fine. The dimming wire isn't getting signal either. I recently replaced the light switch as well. I am wondering if that has anything to do with it. Any help, ideas or references to other posts are greatly appreciated!
Old Jul 3, 2018 | 09:37 PM
iosigma's Avatar
Re: Constant power on radio plug doesn't work
Sorry guys, dug a little deeper into the forum and found out that it was my ARC fuse. Honestly had never even noticed that fuse before. Thanks though!
mustangman65_79
Car Audio
Apr 18, 2015 09:22 PM
paul84z
Car Audio
Apr 12, 2014 04:50 PM
Daveinet
May 29, 2009 06:24 PM
torqueaddict
Car Audio
Sep 13, 2006 05:06 PM
