89 GTA steering wheel controls
Old Feb 16, 2001 | 03:35 PM
smithtc's Avatar
Mine work only when they want to. Why? How can I fix it to where they work all of the time?
Gunmetal 89GTA T-Tops L98
700R4 with 3.27 gears
Best 60 ft: 1.996'
Best 1/8th mile: 9.02 @ 76.5mph with 60' time of 2.14
Mods: air filter, hypertech chip, 3" exhaust
Old Feb 16, 2001 | 05:10 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
That would depend on what the problem is. There is only 1 wire that goes from the controls to the radio. It could be the circuitry within the wheel, the wire or the radio that's at fault. The easiest is to try and swap the radio and/or steering wheel with another in an attempt to troubleshoot the source of the problem.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Feb 17, 2001 | 02:55 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I would guess that the contacts on the buttons are dirty. See if it is possible to pull off the buttons (like you can do to computer keyboards) and clean underneath. If not, they make a product called contact cleaner that comes as a liquid in a spray can. You can spray it under the buttons to clean dirty contacts.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Feb 17, 2001 | 10:30 PM
turbo497's Avatar
sometimes mine are slow to react if it is really cold out. does this problem persent itself only when its cold.
3.8 turbo 20th anniversary transam #497 first owed by Clifford Williams, Bass player from rock band AC/DC
Old Feb 20, 2001 | 06:26 PM
smithtc's Avatar
As far as weather, I don't believe cold causes problems, maybe humidity. That really is the deal, there is no real pattern. Sometimes it works beautifully, and other times barely works, and other times not at all. My radio works fine as far as just pushing its buttons. Maybe it is the "one wire" connecting the radio to the controls. I'll jump on it this weekend and see if I can figure it out. i'd hate to take it to a car stereo shop and get screwed out of my money for a simple fix.
Old Feb 23, 2001 | 10:58 PM
turbo497's Avatar
the buttons work on led slip ring system. Ive since replaced the stock unit with a poineer cd player along with an adapter for the steering wheel bottons. my buttons are slow to react on low subfreezing temps but i don't know if its the bottons slip ring or adaptor that needs to warm up.
One thing that I'm happy about I took out that piece of junk stock radio, the steering wheel controls still work, I Can listen to CD-wr or cd-r, and I now get FM stations
Mike
Old Feb 24, 2001 | 12:28 PM
smithtc's Avatar
Hey Turbo, I too eventually will install a CD player with an adaptor...but am more interested at present in just getting my car to run as fast as yours.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
