HELP! 1988 GTA with Perfromance sound.
Old May 25, 2019 | 01:39 PM
Brandon Felmlee's Avatar
Hello i got a 1988 trans am GTA, with the performance sound package. But had no radio when i bought it as a roller many years ago. Got a aftermarket radio in it and it works but only if you play with the pink wire on the sub relay located behind panel on pass side. prior owner had it cut and wired to somewhere in the radio area in dash. Like i said i can get it to work if i play with the wiring but only if i connect wire to 12 volt positive and unplug it and plug it back in.
Old May 28, 2019 | 12:46 PM
Robert1987's Avatar
Re: HELP! 1988 GTA with Perfromance sound.
Those radios used the power antenna 12volt out put to turn on the amp for perf sound
Old May 28, 2019 | 02:19 PM
So what your saying is to wire the 12V power wire (pink from relay) to the blue power antenna wire and see what happens? Is it maybe that the power antenna does not work that maybe is why the radio does not play sound but turns on?
Old May 30, 2019 | 08:15 AM
Ran that wire from the power antenna still does not turn on unless i play with wire by plugging it in and unplugging it.
punisher1988
Aug 25, 2003 07:43 AM
Buck268
Brakes
May 15, 2002 05:09 AM
Steve10
Apr 26, 2002 02:22 PM
Blade69
Jan 26, 2002 12:56 AM
