Help please!!!!!!!!!
Old Jan 13, 2002 | 03:13 PM
blackbelt's Avatar
I have 89 Camaro with power antenna and it was working fine, until now, I just pulled up and turned off my car and antena went about 3/4 way down then stopped and motor kept going. so turned car back and and it went up and i turned it off and did't go down at all but electric motor is still running. anyone know what to do cause the motor is just running and running even if car is off.
Old Jan 14, 2002 | 09:51 AM
deadtrend1's Avatar
exact same thing happened to my firends firebird so i pulled the ACC fuse first. Then, he really didnt care, and wasnt in to mood to do antennae work in 2 degree weather. He needed lights inside his car (as well as power door locks), so i went through the wheel well and cut the power wires when it was all the way up. No more motorized antennae, but still picks up FM stations which is all you need.
Check to see if yours is bent first. Or maybe a little WD40. Just a few hints.
~Tim
Old Jan 14, 2002 | 01:31 PM
89transam's Avatar
mine was doing that so I just put it down and pulled the antenna (relay?) under the panel in front of the passengers knees. NO more radio, but I was gonna buy one of these on ebay.
They look pretty cool
Hidden antenna
Nate
