What to do next?
Old Mar 6, 2001 | 05:33 PM
steven's Avatar
What to do next?
what should i do, i have a box for 3 12's, what subs should i throw in there and what amp to power them, please include model number and name if you know it. thanks.
191(3.1)V6 1992 Pontiac Firebird,K&N drop in filter, bosch patinum spark plugs, Pioneer reciver, kenwood 4x6's, sony xplod 6x9's, two kenwood tornado 12's with a 300 watt jenson running them, check it out at www.geocities.com/my_92firebird
Old Mar 6, 2001 | 10:28 PM
matthew's Avatar
well, that depends on what you are looking for. If you want the most bass you can get and win some sound competitions, get some top-of-the-line rockfords, mtx, JL audio W6 or kickers. If you want good sound quality go for Infinity, mtx 6000 series, JBL, JL audio W3 and stuff like that
Old Mar 8, 2001 | 12:35 PM
jobryan26's Avatar
JLAudio 12W6's is a great choice and so is Kenwood DB's. I've had 12W6's and now have Kenwood DB's. Hard choice. The Kenwoods has a much higher S/N than the JL's and my whole system Excelon.
'87 Trans Am
305 TPI:
160 Degree Theremostat
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Spark Plugs
Custom Ram Air with K&N
Old Mar 9, 2001 | 11:57 PM
Belker's Avatar
Since you already have a box that you want to use, it is important that you select subs that will work well in the box that you have.
For example, if the box has an internal volume of 3 cubic feet, then you should look for 3 subs that each want about 1 ft3 internal box volume.
This is an important factor in selecting subs that will sound good in your box.
