No Room
Old Mar 4, 2001 | 03:17 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
No Room
Ok I got a NEW Equalizer last night its a sony and it works. Well our trim plate is only so big and with my head unit and the EQ above it there is allot of wires in the back. I cant push the Stero unit all the way back and get the trim plate on right any idea to free up some room back there. Also how do i get rid og enigne nose form one of my amps its a El Chepo model but hey i need an amp lol. I get static in it it sounds liek and goes up with the rpms and i know its engine nose any ideas how to get rid of that.
Old Mar 4, 2001 | 09:15 PM
crows_camaro's Avatar
I had a friend who had that problem with his amp.
He added a noise filter and it eliminated the buzz or whining noise. I have also heard rumors about the alternator or something not being grounded good but I am not sure about that.
Try a noise filter. They aren't expensive so it won't hurt to try
Old Mar 5, 2001 | 09:27 AM
nosaint's Avatar
Car: 1986 Trans Am
Have fun!!!
I have two units stuffed in there too, maybe try reversing the two(the other on top). My DSP has less stuff sticking out. I had to cut some of the console away as well as the mounting brackets. Spent a lot of time and it could still use some more.
1986 Black & Gold WS6
Trans AM...The Muscle Car Lives
...Its just not at home at the moment...
Nosaints Coolzone
Old Mar 5, 2001 | 12:29 PM
myposcamaro's Avatar
you have a 'ground loop'. Where did you ground the amp? Did you use sandpaper to scrape off all the crap so you have good metal contact?
i would just recheck your ground cable. Try to keep it as short as possible. I never really dealt with those filters, so i couldnt tell you. You could try it!
kev
Old Mar 10, 2001 | 03:12 AM
Belker's Avatar
If you're really brave, you may be able to soften the heater ducts within the console with a heat gun while pushing on it with a 2"x4" and get it to bend inwards slightly. This will give you just enough mounting depth if you're lucky. I haven't tried it yet but have heard of it being done. I've also heard of people poking a hole in the duct doing this, then end up also having to fix the hole.
Good luck.
Old Mar 10, 2001 | 04:56 AM
FAST RS's Avatar
All of the noise filters suxk trust me i tried 5 of em never worked i herd msd makes one i will give that a try cuz my 6al messes up my CB
Old Mar 11, 2001 | 04:16 PM
Pete92TA's Avatar
I have a eclipse tape head unit on top with a clarion 7 band EQ underneath. Fits ok wih the right brakett.
http://sites.netscape.net/bulldogfrazier/homepage
http://www.fracoinc.com/
Keep your ride shinning with pride
83RDRACR
Mar 26, 2016 08:13 PM
Briandrex
Oct 5, 2015 06:20 AM
Damon
Sep 26, 2015 04:29 PM
PestilenceIV
Sep 22, 2015 07:39 PM
blackandblue02
Sep 10, 2015 08:19 PM
