Rear speaker harness routing
Old Jul 10, 2020 | 04:19 AM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
Transmission: THM 700 R4
Axle/Gears: 2.73 Stock
Forgive me if this should be in the "electronics" forum.
I'm looking for confirmation that the rear speaker harness runs down the passenger side of the car. That would seem to make the most sense to me since the harness that goes to the rear runs down the driver side and you wouldn't want power next to speaker wires. Are the wires simply clipped in wire loom clips as it travels beside the seat? Once it reaches the rear seats, what is the route that it takes across the car?
The only other possible solution that I could think of, which also doesn't make sense, is that it would travel under the center console on the trans tunnel and then branch under the rear seats to each speaker.
Thanks for any help, this was my own dumb fault for not taking the picture of this (and it's not listed in my 8 billion page service manual). I didn't think it would be 10 years till I had the car back from paint, but that's a whole other story...
Old Jul 10, 2020 | 08:35 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Rear speaker harness routing
Yup, Pass side of the car,.... it crosses over the body to the drivers side at (about) the back of the pass door and runs along the car in front of the rear seat bottoms. There are a couple small metal 'tabs' welded to the body/floor that hold the harness in place as it crosses the floor in the back.
Old Jul 10, 2020 | 08:45 AM
Vachaun22's Avatar
Car: 1986 Trans-Am
Engine: 305 4BBL
Outstanding.
One other quick question. I was watching a video on youtube after carpet had been pulled and what you described is what I thought I was seeing (so I'm glad that has been confirmed), but those wires were in loom. Granted, that particular car was an IROC (not sure of the year), so I'm not sure if that makes a difference. My question is, is the rear speaker harness suppose to be in loom? Mine isn't, and that is one of the harnesses that I didn't touch (read: have repaired) so I don't know if I should re-wrap it in loom or not.
Obviously, the wire is safer in loom, but since I'm doing a restoration and trying not to modify any more than is necessary....
Thanks.
Old Jul 10, 2020 | 03:39 PM
John in RI's Avatar
Yes,..... there should be a loom; don't think I've ever found them not in a loom !?!? I'm sure because the speaker wire loom is small and I often "steal" it from the speaker wiring so I can use the loom to wrap the wiring when installing custom add-on accessories.
kentuckyKITT
Car Audio
Oct 19, 2019 02:18 AM
BOTTLEDZ28
Jan 27, 2016 03:51 PM
Derek The Great
Car Audio
Apr 30, 2005 12:48 AM
