Question - Car Stereo Factory Wiring Route?
Old Apr 6, 2021 | 04:13 PM
Epicamaro's Avatar
Car: 1983 Camaro
Engine: 2.8L
Transmission: 5 Speed Manual
Hi All,
Quick question (hopefully). I'm planning on replacing my stereo and think that this is a good time to re-run the speaker cables that I did a 💩 job at running. The previous owner cut the harness off and took the speaker wire (idk why....). I'm ordering a new harness and I'd like to put things back to factory so I have a question (or 2):
  1. Where did the front/rear (mostly rear) speaker wires run originally?
  2. Where is the factory antenna located? Mine's installed at the right rear quarter panel.
Thanks!
Old Apr 6, 2021 | 10:54 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Question - Car Stereo Factory Wiring Route?
Antenna gets mounted top the top of the pass side fender, near the windshield.
Front speaker plugs/wiring is part of the Dash harness.
Rear speaker wiring is a separate / independent harness that runs from the radio, to the passenger side kick panel, down the passenger side door sill, then it splits: 1) to the passenger speaker & 2) under the carpet, across the car to the drivers side speaker.
HumbleBeginning
Car Audio
Aug 24, 2020 10:31 AM
Alfisti
Car Audio
Jan 10, 2019 08:27 PM
dmyruski
Car Audio
Mar 12, 2012 04:11 PM
youngmiguel
Car Audio
Jun 6, 2006 12:01 AM
jiggajiveturkey
Car Audio
Sep 28, 2003 03:35 PM
