2 ohm load
Old Jan 19, 2002 | 12:02 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
2 ohm load
if i wire 2 subs in paralell to obtain a 2ohm load, can i run that 2 ohm load in 2 channels?
Old Jan 19, 2002 | 01:26 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
No, it will have to be run as one channel since you are making 2 speakers into one by wiring them that way.
Old Jan 19, 2002 | 03:01 PM
Car: 1986 Camaro SC
if i buy 2 subs that have dual voice coils could i run 2x2ohms then>>?
Old Jan 19, 2002 | 03:59 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
Yeah you should be able to run each speaker, with DVC'S running in parallel, to each channel. You might want to verify with a mulitmeter that you are actually getting a 2 ohm load. Make sure your amp is capable of running at a 2 ohm load.
Old Jan 19, 2002 | 04:00 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Here's a really nasty pic of how it should be wired.
This is for two Dual Voice Coil subs, with each Voice Coil being 4 ohms. The green wire is just a nuetral wire. I guess you could call it positive.
http://us.f1.yahoofs.com/users/f4b2a...14fm8AuzS42TCa
This will give the amp a 4 ohm load while it's bridged.
AJ
Fanatic1074
Oct 3, 2022 05:57 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
lewandom
Oct 1, 2015 08:15 AM
ironbmt
Sep 27, 2015 06:00 AM
