Question For Jim and Any Other Experts
Old Apr 12, 2001 | 10:18 AM
88tam's Avatar
Do the cerwin vega vega 15" sub(s) have to be ported? If not, how many cubic feet per sub would you recommend a box having? Thanks?
Old Apr 12, 2001 | 10:27 AM
dallasiroc's Avatar
I am assuming this is the Vega series, either the 154 or 15d4.
They recommend ported enclosures on both models.
Now the size of the enclosure is going to depend on the amount of power you are planning to run.
Let us know what amp and power range to better answer your question.
Old Apr 12, 2001 | 10:45 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The vega series is designed for ported applications and needs a HUGE box. That's the main reason why I don't run vegas.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Apr 12, 2001 | 12:56 PM
88tam's Avatar
****, I was hoping I could get away with using a sealed box and pumping out 500X1 rms. I hate building ported boxes cause they are so damn big.
[This message has been edited by 88tam (edited April 12, 2001).]
Old Apr 12, 2001 | 01:27 PM
dallasiroc's Avatar
Old Apr 16, 2001 | 07:28 PM
Belker's Avatar
I would never, ever put a Vega in a sealed box. You must use a well designed ported box or you will be very unhappy with an otherwise good sub.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
