So I'm rebuilding a power antenna using the GM 22020281 bolt kit. It comes with one, larger flathead screw/nut and 3 Phillips screw/nuts. These replace the 4 eyelets that have to be drilled out to open the antenna case.
Where is the slotted screw supposed to go? Does it matter? I thought it might be for the center hole that goes through the gear and cup assembly, but it can't fit that hole. The Phillips screw will fit that hole. So it must be one of the other 3 holes around the edge of the antenna case?
Just curious if there is a specific place for it or not.
