1989 GTA Steering Wheel Controls Yellow .65 v
Old Nov 1, 2025 | 11:02 AM
henny156's Avatar
Hi,
1989 GTA w/steering wheel audio controls. Controls do not work, LOC on radio.
Orange wire on pad has 12V
Yellow wire has .68 volts, it does fluctuate a bit when buttons are pressed.
Any ideas?
Thanks!!!
Old Nov 1, 2025 | 11:05 AM
henny156's Avatar
Re: 1989 GTA Steering Wheel Controls Yellow .65 v
Sorry, had the wires backwards. Yellow has 12v Orange is .68v
Old Nov 1, 2025 | 03:36 PM
henny156's Avatar
OK, might be making progress.... Should I have continuity from the orange wire on the pad, all the way to the orange wire on the 5-pin 2 wire connector that plugs into the back of the radio?
Old Nov 4, 2025 | 07:18 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Here's an 88 SWC Radio wiring Schematic,... Maybe it will help.
What I see in this schematic is that the Yellow wire is the "switched ignition" signal from the fuse-box. That circuit should carry battery voltage whenever the Key is in Accessory or RUN.
The ORANGE wire is the "data" circuit. You should have continuity,.. if you don't then check the plug connection at the bottom of the steering column. (AKA: C210 on the schematic)
Most GTA SWC radio problems trace back to the PINS on the Turn Signal switch inside the steering column.
Old Nov 5, 2025 | 08:41 AM
henny156's Avatar
Thank you! I will report back once I get some 'me' time...
AngryBird
Interior Parts Wanted
Jan 21, 2024 01:45 PM
suprabob
Car Audio
44
Nov 8, 2023 01:48 PM
KRACKER JACK
Nov 22, 2021 07:15 PM
KRACKER JACK
Car Audio
Nov 18, 2021 08:33 PM
BigWhiteGTP
Apr 24, 2009 11:00 PM
