Just how good are stock speakers? Want to put 4X52 X-plod in.
Old May 13, 2001 | 01:13 PM
Xenodrgn's Avatar
I'm not going for a huge system here, just a CD player where I can listen to tunes while I cruise. Right now the stock AM/FM/Tape can't be turned up all the way cause it sounds like absolute crap. If I were to just replace the head unit will it solve the problem and will the speakers handle it sufficiently?
1985 Camaro SC - 2.8L, auto.
Mods:
Removed air baffles
Maintenance since I bought it:
Bosch Platinum Plugs, Radiator, Water Pump, PCV, fluids and filters
143K and 'The Beast' is still running strong
Old May 13, 2001 | 02:09 PM
DJSexay's Avatar
stock speakers are 8 ohm (maybe even 10 ohm, I'm not sure) so you will only use half or less of the rated power of your cd-player. also, the 4x52 watts is a peak number, I'm sure. My guess is the stock speakers will recieve 10 watts per channel or less. Should still be a noticable improvement. I say go for it.
mike
custom 3rd gen kickpanels at http://www.lachernet.com/kickpanels
Old May 15, 2001 | 02:44 AM
Tigger84TA89BIRD's Avatar
I'd say no...
just replacing the head unit does little to improve your sound...yes you will notice a difference because cd is a better source medium, HOWEVER, the speaker is ultimatly the component that reproduces the sounds that it receives, and quality of the source isn't going to affect it that much, you can't get QUALITY sound out of ***t speakers.
your money will always be better spent on better speakers than a better deck, but a deck is the beginning... replace both if you can
89: stock 305TBI, strut tower brace, MSD6AL, k&n filters,
stripes by AutoTrim Design,
optima wheels,
Kenwood kdcx615s deck,
MBQuart dkd146 4x6,
MBQuart Q series components in custom plates in rear pillars
2 JLAudio 500/2 sub amps
2 JLAudio 300/2 mid/high amps
2 12" soundstream SPLMules in 4 cubic ft box
audiosource 3.1 control center/EQ
154.1db in 1-2 street class
GO TEAM CAR TOYS!!!!
[This message has been edited by Tigger84TA89BIRD (edited May 15, 2001).]
Old May 15, 2001 | 07:44 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I usually also suggest new speakers first because that will give the biggest improvement in sound, BUT, the delco decks are so bad, that I suggest replacing those first. The stock speakers can actually sound pretty good when you adjust the bass/treble a little bit on the new decks. Just don't expect the speakers to survive for long if you crank the bass and the loudness on the deck.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Thirim
Aug 9, 2015 06:19 PM
