Expert Help needed badly!! 2 questions!
Old May 25, 2001 | 01:04 PM
SUPER-SPORT-CHEVY's Avatar
Ok nnobody responded to my previous post I assume that nobody knows about the mtx ts82 series boxes. Well I finally found some nice polk 10's that will fit nicely in the boxes but when i went back to purchase them two sales men with less than a grade school diploma told me that 10's in a box 13,3/16 x 16,1/4 x 7,3/8. will not work! They told me on rebound the subs will stick because of lack of room in the box. Ive seen alot of custom boxes actually smaller running 10's in a sealed inclosure so whats up? Will 10's stick in a box with those dimentions?
Question 2. My new kenwood deck says to use the built in crossover for subs "the subs have to be active" what exactly does that mean? ive played with my 8's hooked up and it would not show the sub controll feature, I even tryed it through the amp with no luck. Do the subs I choose for that have to be in an internally amplified box?
Thanks I hope someone can help!
SSC
Old May 25, 2001 | 03:12 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Not sure on the deck but that box should be ok for most recent 10's, its about .85 cu. ft. which is actually a little too big for most current 10's, usually in the .5-.75 range, go to the mtx website or look on the box of them and find out the recommended enclosure volume, that should tell you if they will be ok or not.
86 Z28, 93 LT1 swap in progress:
93 LT1
T5
Edelbrock Catback
Soon to come: Turbo and intercooler.
Old May 25, 2001 | 09:38 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
That is about right for tens. The .85 is the total box volume, right? Then that's .425 cu ft. per woofer. That sound good for most tens. If the Polks take more than that, then they're unique.
Old May 25, 2001 | 11:17 PM
Thanks for the responce's guys!
I emailed MTX to see what they think on the subject or what they would recomend. I'll probably get whineing about warenty issues but they might give me a straight answer if they email back! It would kinda be cool to take a letter from MTX into that shop and shove it where to sun doesent shine, hehe.
SSC
Old May 29, 2001 | 04:25 AM
Tigger84TA89BIRD's Avatar
Which Kenwood deck do you have? if it has the KEX feature, you have to go into the menu setting and turn it on before you have crossover control on the deck. if you don't, all you have are bass and treble control.
89: stock 305TBI, strut tower brace, MSD6AL, k&n filters,
stripes by AutoTrim Design,
optima wheels,
Kenwood kdcx615s deck,
MBQuart dkd146 4x6,
MBQuart Q series components in custom plates in rear pillars
2 JLAudio 500/2 sub amps
2 JLAudio 300/2 mid/high amps
2 12" soundstream SPLMules in 4 cubic ft box
audiosource 3.1 control center/EQ
154.1db in 1-2 street class
GO TEAM CAR TOYS!!!!
Old May 30, 2001 | 12:06 PM
Finnaly got sub controll !
It's the function where you hold the loud button for a few seconds then it turns on the sub controll, it still needs an external amp but it cuts out all the other noise completly kinda neat if you want a 4 channel amp to produce multiple function.
Thanks for the replys, Im still waiting for MTX to mail back "if they do". I'll be sure to post what they say so I can get some opionions on what replacements they would recomend.
Thanks again.
SSC
[This message has been edited by SUPER-SPORT-CHEVY (edited May 30, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZ1989
Jan 24, 2016 03:55 PM
redmaroz
Aug 16, 2015 11:40 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
