amp for !0" sub
Old Jun 10, 2001 | 03:41 PM
Ragin'87's Avatar
amp for !0" sub
anyone have suggestions on a good amplifier for a 10" Pioneer sub. 120w nominal, 400w max. I don't listen to much rap, and I don't want the sub to really "pound" I'm just looking to hold up ther bottom end. I have a sealed enclosuer.. `1.05 cu. ft.
Anthony
previous ride: 87 Camaro LT
350, A4.Comp Cams 268H, Edelbrock Preformer intake, Hedman Headers and y-pipe, gutted cat, No AIR/smog pump. 14x3" Open element K&N, Q-jet w/ D hanger and DA rods, adjusted AV spring tension and quick can.
Current ride: 1992 Camaro RS, K&N, Flowmaster, 305, T5, Black, T-tops, 76k miles.
Old Jun 11, 2001 | 03:19 PM
Ragin'87's Avatar
oh come on.. no one has any opinions on amps?
Old Jun 11, 2001 | 03:48 PM
Polecat's Avatar
Kicker ZR120 or ZR240.......plenty of power.
Old Jun 11, 2001 | 07:55 PM
GndPrx's Avatar
Uh huh, leave it to polecat to come up with the Kicker j/k Kicker is good stuff.
Other alternatives if you don't want to pop for the Kicker ZR money wise...
Xtant 121M would be a good first choice
Others in no particular order...
Kicker Impulse series
Alpine V12 series
MTX Thunder series
Rockford Fosgate
Most of these lines have amps that would be more than adaquate to power a single 10" sub at a decent cost.
These are just some starting points, but should send you in the right direction.
By the way Polecat, how well does a ZX460 run as a 3 channel? I need to off a bunch of amps I have lying around and pick up a single amp solution for the wife's car.
Thanks...
Carl
CarAudio Resources
[This message has been edited by GndPrx (edited June 11, 2001).]
Old Jun 11, 2001 | 08:38 PM
Ragin'87's Avatar
can anyone shed any light on the wattage issue? I'm still unsure how many watts I should run. should I be closer to the 120w figure of the 400w figure? Thanks for the responses.
Anthony
Old Jun 11, 2001 | 10:10 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
A 100-125 or 130watt RMS amp is what you need to spend the money on. You can go higher without damging the sub, but matching RMS power is the safest route. Actually running a big sub with a little amp is more likely to do damage than the opposite. With a low ower amp, you'll push the amp to hard, trying to get that 10" to sound like a 10", and the amp will hurt the sub. Clean power is more important than max power. You can also check out Kenwood. I don't know the model #, but they make a 150 watt mono sub amp. I think it costs about 100-120 bucks. Checi it out on www.crutchfield.com
Old Jun 15, 2001 | 10:02 PM
Ragin'87's Avatar
I decided on the US Acoustics USX2080, 280 watts bridged. I already ordered it. I bought it based on it's wattage being rated at 12.9V as opposed to 14.4, .01% THD, and 101dB S/N ratio. It was also recommended by 3 audio shops.. just thought I'd update the post. Hope it's got enough to power my sub..
Anthony
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
