Radio Mounting
Old Jun 29, 2001 | 02:34 AM
Trent257's Avatar
Radio Mounting
im putting a din style cd player in the opening, where can i get a good radio mounting kit, that wont make it stick out or look like hell. thanks
Trent
---Car---
89 Firebird
305 v8 TBI
automatic
t-tops
---Stero---
Pioneer DEH-P7300
Infinity 2way 4652 4x6's
Pioneer 4way ts-a6985 6x9's
2(maybee 3) pioneer 12" ts-w303c subs
Futureim undecided about amps, im eyeing up the profile cl800's and maybe a profile for the front, and a pioneer cdx-p1270 1`2 disk cd changer
Old Jun 29, 2001 | 07:04 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
They all stick out. Your new radio is much deeper than the stock radio, so it's necessary for these kits to stick out. The only other choice is to modify the console and make your own kit.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 29, 2001 | 12:14 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
It's not too hard to make your own mounting panel out of ABS plastic. Check out the install I did in my '91. http://albums.photopoint.com/j/Album...newphotos=true I just replaced the factory radio panel with an abs one. To fit depth wise, you may need to slightly modify your heater ducts. (I used a heat gun). To fit the half din EQ I had to lengthen the wires going to the gear select switch.
'91 RS
SFC's & Poly bushings so far.
Quote "If you can't beat them, arrange to have them beaten."
- George Carlin
[This message has been edited by REZN8R (edited June 29, 2001).]
Old Jun 30, 2001 | 10:57 PM
Chris Luongo's Avatar
Go to any car stereo store and tell them you want the Metra 99-4544, the GM Multi-Kit. This is the one that comes in a huge bag, with lots of parts.
Anyway, the kit comes with several different front plates you can choose from, and one of them is flat. Using the flat piece, assemble the kit according to the instructions.
Install the aftermarket radio into the kit.
Pretend like you were going to screw the kit into the car...you'll notice that it won't go all the way in. Notice the black plastic piece that is in the way.
It only takes a few minutes to remove the radio housing from the car...or you can leave it in, your choice. In any event, you want to trim just as much black plastic away as you need to. Leave a little bit, because this piece also holds the console in the car.
By the way, this kit is flat, and does look very nice like you probably want, and it's how I did my car too. But I just wanted to point out that like Jim said, if you have enough skills and time (or money), you could also build your own kit that would look even more custom.
John in RI
Car Audio
Sep 10, 2015 11:24 PM
studebaker60
Sep 7, 2015 12:36 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
