best way to wire
Old Feb 8, 2002 | 09:20 PM
89BlackBirdKid's Avatar
best way to wire
I'm a novice at the whole car audio thing I know what sounds good but not how to hook it up. Well I got a pioneer HU, 4x6's and 3 way 6x9s. I like clean sound not loud sound. I'm hooking the rear ones up to an am and know how to do that the right way but i want to run better wire to the front. do I just take the spliced wire off the harness and connect it to the new thicker guage wire? and then connect the new wire to the spliced wire off the speakers? i ask this becuase the connectors off the speakers are smaller. or would it be better to connect the wire directly to the contacts off the speakers? any help would be much appreciated. No flaming please :-) :hail:
Old Feb 9, 2002 | 08:20 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
weller soldering gun $30
soldering iron $30, 60/40 solder $5, 100watts of instant heat..............priceless.
Old Feb 9, 2002 | 08:23 AM
well lucky me my dads already got a soldering gun that I can use. so i just solder the wires directly onto the speakers contacts?
Old Feb 9, 2002 | 11:06 AM
da BEAST's Avatar
Car: 99 F350 Dually 97 Chevy Venture 97 Honda Accord 89 Mercedes Benz 190 1987 TRANS AM GTA
Engine: Brand new 350 Crate motor
Transmission: Beefed up 700R4
Bingo
Thats the ticket.The more splicing you do is just asking for trouble. So I would directly solder the heavier gauge wire to the terminals verses splicing
Old Feb 9, 2002 | 11:42 AM
Guest
Guest
Posts: n/a
if your goign to amp anything amp EVERYthing. when you go to a show where do you hear most of the sound...... the front. so get better speckers for the front and then AMP them make sure you get an amp with hi-low crossover and then add a sub. i have seen way to many people trying to get bass out of a 6x9 and all they do is blow them. 6x9's and 4x6's are good for mid bass not sub bass. also i bet you about $100 bux they they do not handle 100watts RMS..... i bet it is more like 40watss RMS BUT if you don't want to waste the money and get a 4 ch. amp and want to run them off the head uint then put bass blockers on all the speakers go to a pro shop not a best buy or anything like that. no one there knows what they are talking about...... good luck :-D
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
