NEED DIRECTION
Old Jul 26, 2001 | 09:41 AM
thefastest's Avatar
NEED DIRECTION
I plan to build a box for my hatch but I need to know which direction do I point the subs, towards the gas tank, towards the glass or towards the rear. (I plan to make a box for 2 12 in a sealed enclosure)
Old Jul 26, 2001 | 10:34 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
You might want to reconsider the sealed part with the 12's "depending on box size".
As far as placement its doesent matter where the subs face but you shoul probably allow them some room to breath "5in" space minumun so your best bet is to face them up toward the hatch glass.
SSC
Old Jul 26, 2001 | 10:27 PM
thefastest's Avatar
why should I reconsider the sealed part.
Old Jul 27, 2001 | 06:54 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Most of my boxes have the subs facing up, but I did build a box with a single 12" JL facing toward the back and I was quite impressed with the sound.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jul 27, 2001 | 09:22 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by thefastest:
why should I reconsider the sealed part.</font>
Well it depends on air space. 12's in general are put in closures with breather tubes. Like I said it depends on how much airspace you allow for in the box itself.
Good luck with it! and hey you can always make a sealed enclosure and it its not suffcient whip out the hole saw
SSC
Old Jul 27, 2001 | 12:52 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Sealed boxes are generally the smallest enclosure type you can make. Why is size even being argued here?
'91 RS 3.1
SSM SFC's
Energy Susp. Hyper-flex kit
GTA Sway bars
Clarion, Phoenix Gold, JL Audio, etc.
Quote "If you can't beat them, arrange to have them beaten."
- George Carlin
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
gixxer92
May 18, 2017 11:20 AM
efiguy
Sep 27, 2015 01:30 PM
Lmancha96
Sep 25, 2015 08:11 PM
