Need Help with Amp/Subs
Old Feb 22, 2002 | 01:39 PM
5.0L1992RS's Avatar
For some reason, my subs are not working. The amp is getting power, although the protect light it on. So the first thing I did was to make sure the ground was still connected. It is. Sometimes it will come on then fo back off. Does anyone know what I should do or know what the problem it? Any help is appreciated.
Thanks,
Kevin
Old Feb 22, 2002 | 02:28 PM
riggs86iroc's Avatar
Re: Need Help with Amp/Subs
Thanks,
Kevin
more then likely your amp is blown or you have +'s were -"s are to be or viseversa
[img]http:RIGGS7[/img]
Old Feb 22, 2002 | 07:25 PM
RamAirZ's Avatar
Car: 1999 Camaro Z28
Engine: 5.7
Re: Re: Need Help with Amp/Subs
No, the most likely thing is that you have your subs running at too low of a load, trying to make the amp make power. Like your trying to push a 2 ohm load but the amp isn't 2 ohm stable. This happened to my first system I ever had. What kind of amp and subs are you running? Is the amp a 4 or 2 channel? If the protect light is coming on, and it works sometimes, it is not blown. And switching the + and - would just make the subs hit backwards and not sound good, it wouldn't turn on the protect light. Your amp also might be overheating. Does the amp stay on why the volume is low and then turns off when you go to turn it up?
Asim
Nov 9, 2014 05:58 PM
Veaceonee
Car Audio
Dec 31, 2012 05:10 AM
83 Crossfire TA
Car Audio
Aug 22, 2011 09:53 PM
avro206
Car Audio
Jan 19, 2009 08:45 PM
Kevman
Car Audio
Apr 15, 2008 05:49 PM
