This Pic Explains my question without saying any words.....
Old Aug 23, 2001 | 08:23 PM
FiReBReTHa's Avatar
91 FireBird 305 V-8
Edelbrock Catback, Fourth Gen Console. i have six cupholders. all for starbucks!
ghetto rigged cold air intake,
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
God Created The Earth, And Then Turned Up The Bass
Old Aug 23, 2001 | 09:17 PM
9177's Avatar
Paper plate.
Old Aug 23, 2001 | 09:22 PM
GndPrx's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 9177:
Paper plate.</font>
ROFLMAO!!!
Honestly, what is your question...if it's about the wire between the two RCA's it's one of two potential things depending on what gauge it is.
If it's really thin, it's likely a ground reference to "aid" in noise elimination...if it's a thicker gauge (16 or 18) then it may be a remote turn on lead as some companies do that.
I still like the Paper Plate answer though
Carl
CarAudio Resources
Old Aug 23, 2001 | 09:49 PM
FiReBReTHa's Avatar
"A Man With A Rubber Glove!" -sean connery celebrity jeopardy..
ok, well, i mean, its kinda one of those Brain farts..
you know what it is, but you look at it and its like..... "wow...." -keanu reeves...
now, anyways, its a ground, because, damn, well.... its got a spade, and a open wire on the other end..
i figured hell, Ground, but then what, ground it right on the amp in the same terminal, and i thought it might cause interference, but then i thought more, and then i thought if its remote with DC wouldnt That cause interference?
so then i started going nuts....
if its ground because of spade, GOOD. because then ill run remote lead up the right side with power...
OH and question... will running rcas KIND of near the fuse box be bad? theyre triple shielded but still....
Oh, And nother question...
What kind of paper plate, ?
LOL...
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm, Custom stereo in Progress. Fourth Gen Console. i have six cupholders. all for starbucks!
GheTTo Riggers INC.
*** Created The Earth, And Then Turned Up The Bass
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Aug 23, 2001 | 10:40 PM
rudys119's Avatar
damm that is alot of thinking you did there
i think im gonna have to go to sleep now, all that thinkin made me tired just readin it....
i hope that isnt one of those cheap paper plates, i cant stand them i bought some of them the other day and the damm thing leaked all the grease from my grease burger straight on the table
87 GTA 350 TPI
Mods: K&N Air Filter, New rocker arms, Stage III chip.
Next Mods in line: Exhaust, headers
http://www.geocities.com/rudys120/transam.html
Kills:
Nissa 300zx (dont think it was turbo)
87 Mustang 5.0,
89 Mustang 5.0 (modded)
?? Iroc
00-01? Jaguar driven buy 85 yr old guy
Too many ricers to count......
Old Aug 24, 2001 | 02:12 AM
jobryan26's Avatar
HAHAHAHA
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
Old Aug 24, 2001 | 07:33 AM
GndPrx's Avatar
By the looks of it, I would say Arrow maybe?
If it has a spade, it's most likely a ground reference for the signal wire. Most of the time it doesn't do jack though.
Carl
CarAudio Resources
Old Aug 24, 2001 | 10:44 AM
9177's Avatar
it has to be a cheap one. you know thw kind you need to use 5 or 6 plates just to use it. "Always Save" or "Best Choice"
[This message has been edited by 9177 (edited August 24, 2001).]
Old Aug 25, 2001 | 09:54 PM
FiReBReTHa's Avatar
ok then its settled...
Its dixie.....
i mean, Ground.... ground...
oi......
lol
91 FireBird 305 V-8
GheTTo Riggers INC.
Old Aug 26, 2001 | 01:28 AM
FiReBReTHa's Avatar
cra p guys...
i started thinking again..... (sorry)
what would happen, two Rcas next to eachother, one carrying ground, one carring Remote?
and yes, i have a minimum three stake paper plate limit
91 FireBird 305 V-8
GheTTo Riggers INC.
Old Aug 28, 2001 | 11:34 AM
MY 89 T/A's Avatar
I believe that wire is your remote wire. They do this for convience and less mess. It shouldn't cause interference because there isn't enought amerage going through the wire.
1989 Pontiac Trans Am
305 TPI
Auto
2.73 Rear
Stock
Planned Mods:
Cam
Ported Plenum
3.42 disc rear
Headers and Exhaust
Old Aug 28, 2001 | 01:37 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by MY 89 T/A:
</font>
]Well I do beleive it could be a remote wire yet rule1 is dont put power wires and speaker wires togather. Right?
Yet rule2 is ground the amp to the closest best place possible. Right?
Confused
What brand of RCA's are they? Im sure that a remote wire could be used in the rca's if there was shielding. It looks like there is some sort of tinfoil shiled in the wires so who knows.
SSC
Old Aug 28, 2001 | 03:33 PM
FiReBReTHa's Avatar
and you guys didnt believe me when i told you thinking hurts.....
here's what they are:
http://www.justcaraudio.com/products...3b7a18c42995f&
Old Aug 28, 2001 | 05:02 PM
FiReBReTHa's Avatar
HAHA!
found another pic i took before i installed them...
Old Aug 28, 2001 | 10:08 PM
GndPrx's Avatar
DO NOT use that wire to ground the amp as it appears that is the way you are refering to it. Remember you still need to ground your amp to the nearest chassis point with at least equal gauge wire to your power wire.
Generally ground reference wires are not used at all if that's what it is. Some wire manufacturers claim that you can attach this wire to your amps ground and the other end to your head units ground and that this is supposed to help eliminate noise problems. I have yet to ever see that work.
If it's a remote wire (usually not black though) then it's a very thin one. Usually a remote wire is primary wire at 16-18awg..that wire looks more like 20-22awg to me.
Who knows, since I don't follow Audiobahn much, I would send an e-mail to them asking them what it was intended for.
Carl
CarAudio Resources
[This message has been edited by GndPrx (edited August 28, 2001).]
Old Aug 28, 2001 | 10:31 PM
FiReBReTHa's Avatar
no no, bad monkey!
i have Four gauge ground wire, i mean, where im connecting the ground into the amp, connect the ground for the head unit, (that funny wire) in the same terminal on the amp for the fourgauge ground...
Street Lethal
Apr 30, 2019 12:14 PM
Mickeyruder
Sep 2, 2015 02:45 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
