Lightning Cap Charging Question...
Old Aug 29, 2001 | 04:25 PM
KlayBuRn's Avatar
i have a question...
why do you have to charge your lightning cap before you install it? when you hook it up, doesnt it get charged when you turn the car on? i guess i just dont understand this charging the cap thing, also, if you do have to charge it, do you have to charge it everytime you turn the car off and on ?
Old Aug 29, 2001 | 06:16 PM
ip305's Avatar
who told you have to charge it???
Old Aug 29, 2001 | 06:40 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I'm kinda in the same boat as Klay, why do you need to charge a Cap before you install it? I figured it would charge once you hook it to the batt.
I'm new to this stuff tho, so please give me the info on this cap stuff...
Old Aug 29, 2001 | 06:46 PM
350iroc-z's Avatar
I asked the same question and here is the answer i recieved
https://www.thirdgen.org/messgboard/...ML/000160.html
www.350iroc-z.com
Old Aug 29, 2001 | 09:59 PM
JeffC1500TBI's Avatar
If you don't charge it first via resistor or light you'll find out the hard way. when a capacitor is in a discharged state it looks like 0ohms accross the terminals .. hence a dead short.. as it starts to charge up the resistance increases.. if you hook your power direct to a dead cap (especially a 1 farad) you'll get quite the spark and you can damage and /or blow the capacitor. you only have to charge it once. If you disconnect the battery you'll have to charge it again.. what I do is pull the fuse out for my sub amp which is where the cap is.. then disconnect your battery.. after you reconnect the battery put the fuse back in before turning the car on .. this way you don't have to worry about charging it again..
Old Aug 30, 2001 | 12:52 AM
87tpi420's Avatar
if you got confused ...he pulls the fuse because the cap holds a charge and you must isolate it from the rest of the car so you dont drain it when disconnecting battery
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Damon
Sep 26, 2015 04:29 PM
J.C. Denton
Sep 21, 2015 04:23 PM
Saxondale
Sep 15, 2015 06:42 PM
