What can Rockford subs take?
Old Oct 8, 2001 | 12:50 PM
iroc22's Avatar
Yesterday I bought a Rockford Punch 10" sub and when I brought it home, I noticed that it said 200 watts max on the side. I have a 350 watt Kenwood amp and I was planning on bridging it. I bridged my last sub but it popped after 4 months. The guy at the store i bought it from said that it would take anything i would throw at it and if it busted it would be under warranty. I could get a Clarion platinum 10" for the same price though and it is 400 watts max. My question is, will the Rockford Punch withstand a 350 watt bridged amp?
Old Oct 8, 2001 | 12:59 PM
85IROC-C's Avatar
Yep. No problem. Just make sure your box specs are right, and you'll be just fine. Rockford subs are usually underrated, and almost all the kenwood amps are overrated (on wattage) Your Kenwood is probably somewhere around 280 watts MAX (we're talkin' all kinds of distortion here) and if you bridge it, you'll get somehewere around 310 watts MAX. (again, super distortion)
Good luck!
Old Oct 8, 2001 | 01:25 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Those inexpensive rockfords aren't exactly as over-rated as their better stuff. Those subs are the Circuit City buy-1-get-1 special subs. Private Rockford dealers can't even get those things.
That 350 watt Kenwood shouldn't give it much trouble as long as you don't beat on it like a red headed stepchild. I believe that is the Kenwood's "maximum" power.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 11, 2001 | 01:31 AM
TPI_ElCamino's Avatar
either way you only have one ten wtf? Buy one more then wire the sob's to two ohms and have no wories. the first system i ever had was a 280 watt sony amp and 2 fosgate punch XLC 10"s in induvidual 1.25cu ported boxes, and it beat some @ss. granted i have stepped up since then, but i couldnt have been hapier at the time. it hung with 2 12" 1000 watt systems no prob.
[This message has been edited by TPI_ElCamino (edited October 10, 2001).]
Old Oct 14, 2001 | 01:00 AM
iroc22's Avatar
lol yeah i only have one 10" its hard with a vert f-body to sacrifice that much trunk space. But actually right now I do have two tens in the car as a trial (the punch and a dr.crankenstein) and i maxed out the input sensitivity and it pounds pretty nicely.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
